Circular Motion - Triangular Frame
The discussion revolves around solving a problem involving a triangular frame in circular motion with an accelerating frame. A pseudo-force of 3mg/2 is applied to points B and C in the leftward direction due to the frame's acceleration. The Center of Mass (CoM) is identified as lying at the midpoint between B and C, with a known distance to point A. Participants express confusion about the application of forces and the conditions under which the masses complete a circular motion. The conversation touches on concepts from Lagrangian mechanics, work and energy, circular motion, and kinematics.
Ruler of Hell
I'm going to post all that I figured out or tried. Most of it is really just pieces of information that I don't know how to put together.
The frame is accelerating, so I have to apply a pseudo-force of \frac{3mg}{2} on B and C in the leftward direction.
The Center of Mass of the system lies on the midpoint on B and C. I know the distance between the CoM and A.
I tried energy conservation, taking zero potential at BC. That didn't help either.
i can't see your question
is it a pic?
If i am guessing right, frame is acc. along +X axis so you should apply pseudo force in -X
but i can't understand which is going where and masses should complete a circle in frame of A? ... it will if there is no gravity... and is the figure parallel to ground or what>?
are you familiar with Lagrangian mechanics
not exactyl that i have studied somthing like that but i have studied topics work&energy, circular motion, kinematics, momentum and stuff
  • · Replies 71 ·
  • · Replies 30 ·
  • · Replies 42 ·
  • · Replies 17 ·
