Circular Orbits in SR: Force, mv^2/r, L Conservation
  • Context: Graduate
  • Thread starter Thread starter upurg
    Circular Orbits Sr
The discussion centers on the equations and concepts related to circular orbits in special relativity (SR), particularly in the context of forces such as electromagnetic and gravitational forces. Participants explore the implications of SR on the classical mechanics equations for circular motion and the conservation of angular momentum.
  • Some participants inquire about the expression for circular orbits in SR and how the classical equation F = mv²/r is modified.
  • There is a question regarding whether the force law k/r² changes in SR when considering electromagnetic forces.
  • One participant asserts that orbits, being accelerated systems, cannot be analyzed within the framework of SR, suggesting that SR is applicable only to unaccelerated systems.
  • Another participant counters this by stating that SR can analyze accelerating systems from an inertial reference frame and that non-inertial frames can also be considered within SR under certain conditions.
  • A participant provides a formula for stable circular orbits in general relativity (GR), noting that such expressions may not be necessary in SR under certain conditions.
  • Technical details are shared regarding the four-velocity and four-force in the context of circular motion in SR, including equations involving angular velocity and relativistic corrections.
  • There are discussions about potential typographical errors in the equations presented, with participants correcting each other and clarifying the meaning of variables used.
  • One participant suggests that transitioning from classical mechanics to SR involves a modification of the force expression to include a gamma factor, raising questions about the implications of this change.
Participants express differing views on the applicability of SR to circular orbits, with some asserting that orbits cannot be analyzed in SR while others argue that they can. There is no consensus on the specific equations governing circular motion in SR, and the discussion remains unresolved regarding the modifications needed from classical mechanics.
Participants note the complexity of transitioning from classical mechanics to special relativity, particularly in how forces and motion are described. There are unresolved questions about the definitions and assumptions underlying the equations presented.
This discussion may be of interest to those studying the implications of special relativity on classical mechanics, particularly in the context of circular motion and forces, as well as those exploring the mathematical formulations of these concepts.
upurg
In CM there is this equation of motion for ciruclar orbits:
F=k/r^2=m*v^2/r, where k depends on the force involved.
I know this gets complicated in GR, but is there a simple expression for circular orbits in SR, what happends to the m*v^2/r ?
If the forces are only electromagnetic, does k/r^2 change in SR ?
Also, is the quantity L=mrv conserved in SR, or some modification ?
I want to know what is the equation(s) for circular orbits in SR, in A) electromagnetic force k/r^2 and B) gravitational force if it is possible. Any reference ?
I could be wrong, but SR applies to unaccelerated systems. Orbits, by definition, are accelerated systems; therefore you will not find orbits in SR.
Further for SR to be of any interest you need to have a substantial fraction of c involved. Orbits at that speed would be in the world of QM. Once again, no SR orbits.
As it turns out that is wrong, in SR one can easily analyze the behavior of accelerating systems from the perspective of an inertial reference frame, and the modern view is that even non-inertial frames are considered part of SR if the curvature of spacetime is zero. See Can special relativity handle acceleration? from the Usenet Physics FAQ for more info.
If you meant GR, on the other hand, there exists such an expression. If I remember correctly, it is
[tex]r \left( \frac{d\phi}{dt} \right)^2=v=\sqrt{\frac{GM}{r-\frac{2GM}{c^2}}}[/tex]
Where [tex]t[/tex] is the time measured by a comoving observer.
As you can see, you don't need the general relativistic correction when [tex]r>>\frac{2GM}{c^2}[/tex].
Note also that stable circular orbits only exist when [tex]r>\frac{3GM}{c^2}[/tex] because of the speed limit of [tex]v<c[/tex].
In units where c=1 f you start with uniform circular motion, we have an equation for the worldline (parameterized by coordinate time):
[tex]s=(t,r\;cos(t\omega),r\;sin(t\omega),0)[/tex]
which gives a four-velocity:
[tex]u=\frac{ds}{d\tau}=\left(\frac{1}{\sqrt{1-r^2\omega^2}},-\frac{r\omega\;sin(t\omega)}{\sqrt{1-r^2\omega^2}} ,\frac{r\omega\;cos(t\omega)}{\sqrt{1-r^2\omega^2}} ,0 \right)[/tex]
and therefore a four-force:
[tex]f=\frac{d(mu)}{d\tau}=\left( 0, -\frac{mr\omega^2\;cos(t\omega)}{1-r^2\omega^2} , -\frac{mr\omega^2\;sin(t\omega)}{1-r^2\omega^2}, 0\right)[/tex]
So the magnitude of the four-force is:
[tex]|f|=\frac{m r\omega^2}{1-r^2\omega^2}[/tex]
In relativistic physics, the Born coordinate chart is a coordinate chart for (part of) Minkowski spacetime, the flat spacetime of special relativity. It is often used to analyze the physical experience of observers who ride on a rigidly rotating ring or disk.
http://en.wikipedia.org/wiki/Born_coordinates
I think there's a typo above, and the force should be
[tex] f=\frac{d(mu)}{d\tau}=\left( 0, -\frac{mr\omega^2\.cos(t\omega)}{1-r^2\omega^2} , -\frac{mr\omega^2\.sin(t\omega)}{1-r^2\omega^2}, 0\right)[/tex]
Easy to do with so much Tex.:wink:
Oops! :redface: thanks for the heads-up. I have fixed it.
Doesnt look like it's corrected, two dots missing, is m rest mass of the orbiting object? And f points radially inwards ?
It is correct, the dots were also mistakes. Yes, m is the invariant mass of the orbiting object, and yes, f points radially inwards.
Awesome, also, if w=v/r, then this force is just gamma^2 * mv^2/r, so all we need to do when going from CM to SR is v->gamma*v ?
  • · Replies 24 ·
  • · Replies 108 ·
9K
