chasrob said:
Unfortunately, can’t find an explanation of the figures on that web page.
There is an equation known as as the Vis Viva equation that gives you the orbital velocity of your object if you have the mass of the object it is orbiting, its present orbital distance and it average orbital distance (also known as the semi-major axis of the orbit)
it is
$$v = \sqrt{GM \left ( \frac{2}{r}- \frac{1}{a}\right ) }$$
where r is the present orbital distance and a the semi-major axis. note that for a circular orbit, r=a and you get
$$ v= \sqrt{\frac{GM}{r}}$$
If you just have the perigee and apogee of the orbit of an elliptical orbit, you can get a from taking the average : (r
p+r
a)/2
Now you can get the orbital velocity at perigee of your elliptical orbit. To go from a circular orbit of equal radius to the the apogee, you have to change velocity from circular orbit speed to elliptical orbit apogee speed. Your required velocity change will be the difference between the two.
After all this you can arrive a the following equation for orbital transfer:
$$ \Delta v = \sqrt{\frac{GM}{r_1}} \left ( \sqrt{\frac{2r_2}{r_1+r_2}}-1 \right )$$
Where r
1 is the radius of the circular orbit you are starting from and r
2 is the perigee of the new elliptical orbit. ( it also works if your starting orbit (r
1) is at the perigee of the new orbit and r
2 is the apogee of the new orbit.)
From the numbers you gave and the answer you got, I assume the apogee and perigee numbers you give of your orbit is measured from the surface of the Earth rather than the center (a 500 km perigee as measured from the center is below the Earth's surface), in which case you have to add the radius of the Earth to your numbers before plugging them into the equation since this equation assumes that r
1 and r
2 are measured from the focus of the orbit.
Would it be possible to determine the period of that final orbit and whether its pro or retrograde?
Also, its velocity at perigee and apogee?
The period is found by
$$ T = 2 \pi \sqrt{\frac{a^3}{GM}}$$
With 'a' found as above. Since you a just subtracting enough velocity to drop the perigee, which will be less than the starting orbital velocity, the new orbit will be in the same direction as the starting one. The Vis Viva equation I gave earlier will give you perigee and apogee velocities.
