Undergrad Clarification Rq for linear density
The discussion centers on the interpretation of maximum load readings for elevator wire, specifically whether the weight increases with length. The maximum load of 0.492 kg/m refers to the weight of the wire itself, not its carrying capacity. Therefore, for a 2-meter length, the total weight would be 0.984 kg, not the capacity. The thread was temporarily closed for moderation due to safety concerns regarding the application of the wire. Clarification on the specific use case is required before further discussion can continue.
hassannnnnnnnnn
TL;DR
I am trying to choose Elevator wire, chart shows max load reading in KG/m. Does it mean if length increases weight will increases as well ?
Example;
If max load of wire is 0.492kg/m.
And i am using 2 meter does it mean capacity of wire would be 0.984 kg/m.
Example;
Are you sure this isn't the mass of the wire?
Likes Motore
If max load is 0.492 kg/m, capacity of a 2m wire would be 0.984 kg. Not kg/m.
Likes hassannnnnnnnnn
Thread closed temporarily for Moderation.
@hassannnnnnnnnn -- The word "elevator" has several possible meanings, including some applications that affect life safety. Please send me a private message (PM -- click on my avatar and "Start a conversation") to let me know exactly what your application is. If it is a simple lift for transferring food between floors or something, we may be able to allow that discussion. Thank you.
Example;
I don't believe you are reading the chart correctly. If you are asking about 11 mm wire rope, the weight of the wire rope is 49.2 Kg per 100 m, or .492 Kg/m. The carrying capacity is completely different.
Likes berkeman
No message to me from the OP, so the thread will stay closed for safety reasons.
  • · Replies 44 ·
  • · Replies 17 ·
