Clarification Rq for linear density
The discussion revolves around the interpretation of linear density in relation to elevator wire specifications, particularly focusing on whether the maximum load reading in kg/m indicates the weight of the wire or its carrying capacity. Participants explore the implications of wire length on weight and load capacity.
  • One participant questions if the max load of 0.492 kg/m refers to the mass of the wire itself.
  • Another participant asserts that if the max load is 0.492 kg/m, then for a 2m wire, the capacity would be 0.984 kg, not kg/m.
  • Some participants clarify that the weight of the wire is expressed in kg/m, and this does not represent the load capacity the wire can support.
  • A participant references a chart to support their claim about the interpretation of kg/m in relation to wire specifications.
  • There is a mention of the need for clarification regarding the application of the elevator wire due to safety considerations.
Participants express differing views on whether the kg/m measurement pertains to the mass of the wire or its load capacity. The discussion remains unresolved with multiple competing interpretations present.
There are limitations regarding the clarity of the chart referenced and the definitions of terms used, which may affect the understanding of the wire's specifications.
hassannnnnnnnnn
TL;DR
I am trying to choose Elevator wire, chart shows max load reading in KG/m. Does it mean if length increases weight will increases as well ?
Example;
If max load of wire is 0.492kg/m.
And i am using 2 meter does it mean capacity of wire would be 0.984 kg/m.
Example;
Are you sure this isn't the mass of the wire?
If max load is 0.492 kg/m, capacity of a 2m wire would be 0.984 kg. Not kg/m.
Thread closed temporarily for Moderation.
@hassannnnnnnnnn -- The word "elevator" has several possible meanings, including some applications that affect life safety. Please send me a private message (PM -- click on my avatar and "Start a conversation") to let me know exactly what your application is. If it is a simple lift for transferring food between floors or something, we may be able to allow that discussion. Thank you.
Example;
I don't believe you are reading the chart correctly. If you are asking about 11 mm wire rope, the weight of the wire rope is 49.2 Kg per 100 m, or .492 Kg/m. The carrying capacity is completely different.
No message to me from the OP, so the thread will stay closed for safety reasons.
  • · Replies 128 ·
12K
  • · Replies 44 ·
