Classical Hamiltonian: Energy Conservation?
4 replies · 4K views · last reply
KFC
If the classical Hamiltonian is define as
[tex]H = f(q, p)[/tex]
p, q is generalized coordinates and they are time-dependent. But H does not explicitly depend on time. Can I conclude that the energy is conserved (even q, p are time-dependent implicitly)? Namely, if no matter if p, q are time-dependent or not, if H does not contains [tex]t[/tex] explicitly, I find that the Poisson bracket
[tex]\left\{H, H\right\} \equiv 0[/tex]
so the energy is conserved, right?
But what about if H explicitly depend on time? According to the definition of Poisson bracket, [tex]\left\{H, H\right\} \neq 0[/tex] ?
Short answer is YES!
Long answer. Once the hamiltonian is defined the the time evolution of any quantity is given by:
[tex]\frac{d}{dt}F = [[H,F]] + \frac{\partial}{\partial t}F[/tex]
where [[ ]] is the Poisson bracket and the partial derivative applies to explicit time dependence. Since:
[tex][[H,H]] = 0[/tex]
and there is no explicit time dependence you get:
[tex]\frac{d H}{dt} = 0[/tex]
Expand this in terms of p and q time dependence and you'll get a relationship which becomes the Jacobi identity when you introduce Hamilton's equations.
Thank you so much. I look up the evolution relation in some textbook, but it reads
[tex]\frac{d}{dt}F = [[F,H]] + \frac{\partial}{\partial t}F[/tex]
I wonder if I should exchange F, H in poisson bracket?
I wonder if [tex][[F, H]] = [[H, F]][/tex] ?
No actually [tex][[F,H]] = - [[H,F]][/tex]
But there is a convention choice which is not quite uniform in the sign of the Poisson bracket. Its a matter of whether you define:
[tex][[A,B]] = \frac{\partial A}{\partial p}\frac{\partial B}{\partial q}-\frac{\partial B}{\partial p}\frac{\partial A}{\partial q}[/tex]
vs.
[tex][[A,B]] = \frac{\partial A}{\partial q}\frac{\partial B}{\partial p}-\frac{\partial B}{\partial q}\frac{\partial A}{\partial p}[/tex]
(note p and q are reversed.)
To conform with your reference reverse my Poisson brackets. (I recommend you stick to convention and do this.)
I prefer to (buck convention and) reverse the sign/order so that for canonical conjugate variables U and V:
[tex]\frac{d}{dV} F = [[U,F]][/tex]
This fits better with the conventions for generators in Lie algebras.
vs.
Got u. Thanks a lot. X'mas
