Effect of Additional 1/r^2 Potential Energy on Elliptical Motion
  • Thread starter Thread starter LionMagnus
    Classical Mechanic
The discussion focuses on solving a homework problem involving a particle's potential energy field described by U(r) = -GMm/r + Cm/r^2. The additional 1/r^2 term acts like a centrifugal force, influencing the particle's radial and angular motion. To analyze the elliptical motion, one should define u = 1/r and use the Euler-Lagrange equation to derive constants of motion, particularly angular momentum. The resulting equation for r(θ) is a standard form that reveals the nature of the orbit based on the eccentricity ε. Understanding these concepts and consulting the textbook is essential for solving the problem effectively.
LionMagnus
Hi, this is one the problem on my homework, but I don't know where t start with this problem. We have equation of a particle's potential energy field:
U(r)=-GMm/r+Cm/r^2 C is just a constant. I need to solve for its radial motion and angular motion, then if the motion of the particle is elliptical, what will be the effect of the addtional 1/r^2 potential energy term? Any amount of help will be appreciated!
No attempt yet, don't quite know where to start
The potential you have written down has a 1/r term and a 1/r^2 term. The first is the gravitational potential, and the second has the same effect as a centrifugal force, and will simply add to that term. The standard way of solving the equation of orbit involves a few tricks. First define u = 1/r. The rewrite d/dt in terms of some constant multiplied by an azimuthal derivative, say d/dθ. Finally use the Euler-Lagrange equation to identify constants of motion (hint: angular momentum is conserved, this will give you the azimuthal motion). Rewrite the radial equation of motion in terms of all these new variables. Now you have a standard differential equation for which the answer is know. I don't know if you're really expected to go through all this (it should be in your textbook) but the upshot of it all is that r(θ) = a/[1+εcos(θ)], where a is some constant, and ε is the eccentricity, both constants of integration determined by initial conditions. The magnitude of ε (whether it is between 0 and 1, or greater than 1) will determine if you have a bounded or unbounded orbit. This should get you started. I would strongly recommend reading up on this material in your textbook.
  • · Replies 30 ·
