"Classical Physics Is Wrong" Fallacy - Comments
142 replies · 18K views
PeterDonis said:
This is philosophy, not physics. Philosophy is off topic in this forum.
Means all the postings will be deleted again, even if they are about important things about philosophy of science, which have serious consequences for fundamental physics, because what is criticized would completely destroy the justification for studying TOE or QG?
PeterDonis said:
What do you mean by "my greater error"? You have been treating "wrong" as a binary category. Asimov isn't.
I treat true and false, right and wrong as binary categories. To express what Asimov means with "wronger", which is a continuous scale, I use different words, namely the word "error", which can be greater or smaller. "Wrong" means the error is greater than zero.
PeterDonis said:
Okay, then please justify the claim I just quoted above, that "all our actual theories are false".
For a theory to be true, it has to be true universally. (A "partially true" theory is, similar to "wronger", inaccurate playing with words.) The established candidates for this are only two, GR and QT.
A true theory will not have singularities. GR has singularities.
A true theory will not have inconsistencies. QT, in its standard interpretation (Copenhagen) is inconsistent, it allows different descriptions of the same reality, with different cuts between quantum and classical part, and makes incompatible claims about them. Namely, that the information about the quantum part given by the wave function is complete, while in the description where the quantum part is smaller contains additional information, namely about a classical trajectory of the part between the two splits. Attempts to interpret QT without a classical part have failed, leading to absurdities like many worlds, and if one, instead, accepts that there is additional information, then QT is at least not complete. And an incomplete theory is, quite probable, not true. The quite natural completion proposed by dBB theory has infinities for the velocity near the zeros of the wave function, thus, has singularities, and therefore fails to be true.
As you see, to show that the theories are false, I have to provide arguments, and the arguments lead, naturally, to attempts to solve them by improving the theories.
PeterDonis said:
It is? What is your basis for this extremely strong claim?
The claim is not that strong. And the basis is, very simple, that there is even an established abbreviation for a theory which is universal, namely TOE. TOE denotes a research program, and while we cannot be sure that it will be successfully finished, and while the first attempt, string theory, clearly fails, there is at least a reasonable hope that some other proposal may be successful, and that this success may be reached during the time of my life.
A TOE following the actual research programs will be, nonetheless, a sort of a field theory, thus, full of infinities, and probably viable only as an effective field theory, and therefore also be false. But not because it is not universal. It will be universal, in the sense that it would cover all particles, fields, forces, all what is covered by physics, all what we have observed.
Asymptotic said:
Can you provide examples of non-actual theories that are true?
Out of the existing theories, one can develop approximate theories which explicitly restrict their domain of applicability as well as the the accuracy of their predictions. Some of them may be true. Following standard (Popperian) scientific methodology we cannot prove they will be true even if they are true, moreover, they have much less empirical content, so it is not really a good idea to develop them in detail.
Orodruin said:
Besides, it is not what the insight is talking about. It is addressing the ”so it should not be used” issue. Discussing anything else here would seem off topic to me.
I would not have started this discussion if the title would have been "The 'classical mechanics should not be used' fallacy". The only objection imaginable would have been the question where you have seen such a fallacy and why would one think that such a crank idea is worth to be discussed in a science forum.
The heavy resistance from I meet here, mainly from the moderation team, is something which surprised me. A simple "ok, the title is misleading, it should have been 'classical mechanics should not be used fallacy', do you want to argue that it really should not be used?", would have been sufficient, I would have answered "Of course not, the title is indeed heavily misleading, that's all." Case finished. But, surprisingly, it is this misleading title which is heavily defended. It looks like it is really important at least to some of my opponents that there should be no longer any binary notion of theories being true or wrong.
No, this is just wrong (demonstrably). The justification for studying quantum gravity is that we expect that GR and quantum mechanics to break down in particular limits. A theory of everything is a different matter, you can never say that you have demonstrably found it. At most you can have an internally consistent theory that is compatible with all data that is available.
So, in other words, you are using a different nomenclature than others have used in this thread and in linked references. That is no basis for a discussion.
Yes it is.
No it doesn't. Not unless you are using a different meaning for the word "research program" as well.
What do you base this on. Again, please provide references because this is just pure speculation. You do realize that many people thought everything had been discovered in the early 20th century, right?
(My emphasis) This is very very different from attaining a theory with some higher form of "truth". I hope you see the difference.
But that is not how people stating it puts it. The argument is typically presented in the manner described in the text. If you have not read the text and/or not understood it, I do not think you should enter the discussion after just reading the title. To answer your second sentence: If you had been around for any amount of time you would have realized that this is indeed a fallacy that appears in new posters from time to time. The people suffering from it indeed think it worth discussing in a science forum, which is exactly why the insight was written in the first place so that it does not have to be explained in thread after thread! Instead, you have decided (after not having been here actively) to go off on the wording in the title without actually reading/understanding what the insight is about. Yes, I would therefore expect this part of the conversation to be deleted.
No, your case is not finished because your argument is not valid. Again, this is how the fallacy presents itself. Instead of reading and understanding this, you have chosen to start a strawman argument, which is never a good thing to do.
ZapperZ's usage is problematic, even if one reads beyond the title:
"These are all FACTS, not a matter of opinion. You are welcome to check for yourself and see how many of these were done using SR, GR, or QM. Most, if not all, of these would endanger your life and the lives of your loved ones if they were not designed or described accurately. So how can one claim that classical physics is wrong, or incorrect, if they work, and work so well in such situations?"
Quite a flock of words, but no examples. Please provide an example of a true, non-actual theory.
Karl Popper once expressed the meat of the argument this way, "There are uncertain truths — even true statements that we may take to be false — but there are no uncertain certainties. Since we can never know anything for sure, it is simply not worth searching for certainty; but it is well worth searching for truth; and we do this chiefly by searching for mistakes, so that we have to correct them.".
Think about it this way. We cannot say that all possible theories are false, because we cannot rule out that the universe is finite and discrete. If it is finite and discrete, then it is conceivable that there is a theory of everything that is perfectly accurate.
And why would this be a reason to develop some completely unnecessary theory of QG? It would not be better than GR and QT, because everything we can test is covered either by GR or by QT. Some minor issues where both are necessary are covered by QFT on curved background. Which is internally inconsistent, but once it makes all the accurate predictions, it is not wrong too. So, everything is fine.
I use the standard meaning of the words, as established over centuries. This standard meaning tells, uniquely, that classical mechanics is wrong, and this was established by the first experiment which has experimentally falsified classical mechanics.
We have the SM of particle physics, and actually nothing in particle physics is in contradiction to the SM. We have GR, and a model of cosmology in agreement with GR. Dark energy may be described by the cosmological term of GR, dark matter with a simple massive scalar field not interacting with other fields, so that
all what is not covered by the SM is covered by GR. Both the SM and GR are quite similar theories, namely effective field theories. Of course, every expectation about the future remains in some sense pure speculation, but all I need is the hypothesis that two effective field theories may be unified into a single one.
Given that I do not at all claim that everything has been already discovered, why do you think your remark is relevant? (BTW, how it makes sense to claim, at a time when people have learned to see the spectral lines of various materials, without having an explanation for them, that everything has been already found is something I have never understood.)
I do not care about "higher forms of truth" (religious?) at all. What I care about is the standard, everyday form of truth, which rejects something as false if it is falsified by observation, internally inconsistent, or in conflict with other things considered to be true. The definition is the simple straightforward correspondence to reality. I recognize very well that there may be theories which are consistent and compatible with everything we have observed up to now but are nonetheless wrong, so that we can never be sure that we have found the truth, even if in reality we have found it. This does not make truth something higher, it is simply a consequence of our very restricted human abilities to identify false theories as false.
I have read the text and understood it. It does not prove at all what is claimed in the title '"Classical Physics Is Wrong" Fallacy'. Instead, it created a strawman "There is somehow a notion that SR, GR, and QM have shown that classical physics is wrong, and so, it shouldn’t be used." and then attacked and killed the "it shouldn’t be used" part of it. I criticize this. (If I had read somewhere only the title, I would have ignored it as I ignore the usual "logical errors made by einstein" nonsense, but given that I don't think that PF insights is a place for such nonsense, I have taken a look at it.)
Maybe, ok. Then what I have named "the only objection imaginable" would be wrong or weak. And the suggestion to name the insight appropriately, '"Classical Physics should not be used because it is wrong" fallacy' remains.
If a fallacy hides itself behind a true statement, this does not make the true statement a fallacy.
In this case, 'The "Classical Physics is wrong" cover for the "Classical Physics should not be used" fallacy' would be the appropriate title.
"Classical Mechanics is wrong" is not a fallacy, but a simple well-known truth.
What has surprised me are the open attacks against the very idea of truth, and the defense of the misleading title, and all this not from a single freak, but consistently from many participants:
Orodruin: "Any talk of a ”true” theory is useless and ultimately not constructive or scientific as you can never prove that your theory is ”true” in some deeper meaning."
PeterDonis: "The whole point is that "correct" and "wrong", binary categories, are not useful categories to use when talking about scientific theories and approximations."
Dale: "The experimental results are the relevant demonstration, and in the classical domain the approximation is experimentally valid. You can call it an approximation, a limit, or a flubnubitz, and what you call it does not change the experimental facts that validate it."
russ_watters: "Which - again - means you may as well use "wrong" in a relative sense so that the word is useful. Otherwise a statement like "that theory is wrong" is pointless/redundant."
Please note also that I would not have a problem with a philosophical discussion about various theories of truth, where the (classical and Popperian) correspondence theory of truth is questioned, and various alternatives like relative theories or consent theories of truth are defended. There are reasonable, scientific ways to discuss such things. But what is common to them is that they would not try to question the use of words used in the other theory of truth. If the same word, here "truth", would be given a different meaning in different theories, fine, the standard scientific way would be to introduce add a qualification to the word, say, "consent theory truth" vs. "correspondence theory truth", and this would be necessary only if the same word is used in a different meaning in the own preferred theory. If the word is not used at all in the own theory, one would leave it to the other theory which has a use for it. And the only aim which makes it useful is the Orwellian one - the evil theory will be left without the words necessary even to think about it.
Maybe I'm wrong if I see such an Orwellian element in the quotes above? I hope so.
The "No True Scotsman" fallacy.
Following David Bohm in "Wholeness and the Implicate Order":
"Thus, it might be said that a theory is primarily a form of insight, i.e. a way of looking at the world, and not a form of knowledge of how the world is."
"So, instead of supposing that older theories are falsified at a certain point in time, we merely say that man is continually developing new forms of insight, which are clear up to a point and then tend to become unclear."
And inherently impossible to ever know if we've found one. Making a binary definition of "wrong" useless from a practical standpoint.
The existence of something being conceivable is a very different statement from the statement of existence.
That it is not testable now does not mean that it is a priori untestable.
As a particle physicist I can tell you that this is factually wrong. I am not going to comment on the other fields that I am not working in.
Yes you are, even if you are not realising it. Science does not care about "truth" in the way you are presenting it. The way you are presenting it is very close to an idealised religious view.
In the case of your underlying "truth", no. These discussions cannot be settled by experiment and therefore do not belong in empirical sciences. If you want a scientific discussion you should, in principle, in the end (when all predictions have been made) go out and measure something to determine who was right. There is a reason we typically do not engage in philosophic discussions here.
atyy said:
An approximation is wrong in the sense that an approximation contains an error.
Sure, such an error exists, but if the error in the approximation is smaller than the experimental precision then neither theory is wrong. In other words, what determines whether a theory is wrong is disagreement with experiment, not disagreement with another theory. The error discussed here is therefore not directly relevant to the validity of a theory.
Of course, there will be always some minor disagreements. But is there anything serious enough that one can reasonably say the SM has been falsified by observation?
It is standard correspondence theory of truth, as, for example, defended by Popper.
Discussions about the scientific method are, of course, not empirical science themselves. Which is a triviality. (Ok, you can propose different alternative scientific methods, leave different groups of scientists developing science following them, and compare the results. But this is not really what is done in discussions about the scientific method.)
The obvious reason is that such discussions are unwanted here and will be simply deleted. Beyond this, there is no good reason to avoid in a scientific forum discussions about the scientific method, and discussions about the scientific method are inherently not discussions about particular scientific theories, but about methods to find and evaluate them.
Yes, but in the context of the discussion the question which theory is true was settled by experiments a century ago, and no longer open. Today we already know that it is classical mechanics which is wrong, and therefore all for what it remains possibly useful is to compute approximations for better theories. Similarly
Dale said:
You have the purpose of this calculation backwards. The purpose of computing the difference between Newtonian mechanics and relativity in the classical domain is to establish the validity of relativity. Newtonian mechanics is already validated by experiments in that domain, and therefore relativity must show that any disagreements between it and Newtonian mechanics are less than the experimental precision.
This was the purpose for Einstein to show that his theories have a classical limit, or later for the correspondence principle in quantum theory. Once it was clarified in this way that former experiments which supported classical theory were not in contradiction with the new theories, this issue was settled. Today it is irrelevant. Today we know that classical mechanics is wrong and GR/SM are better, and the only justification for using classical mechanics is to use it as an approximation for these better theories.
Neutrino masses. Neutrinos are massless in the standard model but need to be massive in order to accommodate neutrino oscillations, an observed phenomenon. Of course, this does not stop us from using the standard model whenever neutrino masses can be ignored, which is most of the time.
You also have precision measurements such as the muon anomalous magnetic moment or the invisible Z decay width, which do not agree with their standard model predictions.
The criterion for what topics are allowed for discussion here is not what you, or anyone else, thinks is important. It is whether the question can be settled by experiment. Questions about philosophy, including philosophy of science, can't. So discussions of them end up with people simply restating their opinions and nothing ever getting resolved. Just as is happening with this discussion.
If you don't think funding of study of TOEs or QG is justified, PF is not the place to argue that point. You need to convince the people who are actually providing the funding.
Yes, that's obvious. And I'm pointing out to you that, as applied to scientific theories, this treatment is useless, since we have never found a true theory by this definition, and the binary categorization fails to capture the actual useful distinction between theories, namely, how accurate they are when compared to the data.
No, the context for this discussion is in the classical domain where (tautologically) classical mechanics is right as has been validated by a multitude of experimental data. This is precisely the point of the article which you seem to be missing.
The fact that classical mechanics is demonstrably invalid in the quantum or relativistic domains does not change the fact that it is demonstrably valid in the classical domain. All it does is limit the domain of validity of classical mechanics, not invalidate it in the classical domain.
Furthermore, classical mechanics is a part of both relativity and QM, so classical mechanics cannot be “wrong” and relativity/QM be “right”. If you call relativity “right” then so is classical mechanics since it is part of relativity.
No, classical mechanics remains as right today as it was in the 1800’s. All of the evidence that validated it then still validates it today. None of those experimental confirmations have gone away.
Evidence outside of the classical domain establishes the limitations of the domain of validity of classical physics, but does not invalidate it in the domain where other experiments validated it.
You may not recognize it, but this is a pretty severe problem with your approach. Suppose that tomorrow we discover incontrovertible experimental evidence contradicting GR/SM in a previously untested domain. According to you, they would then be “wrong” in a binary sense.
Since we do not have a better theory you would have no justification for using GR/SM, and no justification for using classical mechanics either. All of the previously accumulated experimental validation would be moot, because according to you, the only justification for using a “wrong” theory is if it is an approximation to a better theory. You, and anyone taking your approach, would be unjustified in doing anything related to any prediction of SM/GR or classical mechanics until such time as a better theory could be developed and shown to reduce to SR/QM and classical mechanics.
On the other hand, people taking my approach would rationally continue to use SR/QM and classical mechanics within their respective experimentally confirmed domains of validity. Like you, we would have no theory to cover the new domain, but unlike you we would not discard our existing theories in their domains. We would confidently expect classical mechanics and SM/GR to continue to work as well as they ever did, not because we can show them to be a good approximation to a better theory, but because they have each been experimentally validated in their own right.
I disagree, ZapperZ opens by mentioning SR/QM/GR etc. In that context, it is completely standard to say that Newtonian physics is wrong. ZapperZ's choice of words is unconventional.
Also, it is a fine point whether Newtonian physics is "right" and without error even at low speeds. It is reasonable to consider SR is the better description of reality, so even at low speeds, Newtonian physics is only an approximation to the "true or truer theory of reality", and is still wrong.
It is basically the poor choice of words in the Insight that is triggering the discussion, otherwise there would have been no need for Orodruin to try say in an earlier post "Besides, it is not what the insight is talking about. It is addressing the ”so it should not be used” issue. Discussing anything else here would seem off topic to me."
I am amazed and puzzled by the amount of discussion triggered by this article, not even remotely controversial. I'd say the message of the article was pretty clear, so using all this sophistry to rip the article apart acts only to discourage the author from ever again publishing anything us laymen can understand. I know I would be.
I think only philosophers care about "truth" and "right/wrong". (And perhaps mathematicians.) As much as I love philosophy, I am starting to see why these discussions are not allowed on PF.
Again, you are making the unjustified “approximation” means “wrong” claim. In the classical domain the experimental evidence validates Newtonian mechanics.
What sophistry? The correct point is that even though Newtonian mechanics has been shown to be wrong, it is still useful.
No, it is justifiable. I agree it can be disputed, which is why I said it is a fine point, but that is the philosophical discussion I thought the mentors were trying to avoid.
The simple point is that the word choice in the Insight was poor.
And because the discussion still seems to be focused on the word "wrong", this thread is closed.
