Is Clock Synchronization Truly Possible According to Einstein's Theory?
  • Context: Graduate
  • Thread starter Thread starter bernhard.rothenstein
The discussion revolves around the concept of clock synchronization in the context of Einstein's theory of relativity. Participants explore the implications of synchronizing clocks using light signals, the assumptions involved, and the potential issues that arise when considering different frames of reference. The conversation touches on both theoretical and conceptual aspects of synchronization, as well as its practical applications in scenarios like GPS.
  • Some participants discuss the synchronization of clocks C(0) and C(x,0) using light signals, questioning whether the initial conditions are adequately stated.
  • There is a suggestion that the concept of synchronization might be more aligned with Newtonian principles rather than Einstein's, particularly when both clocks are at rest.
  • One participant raises a concern about the assumption that light takes the same time to travel both ways between clocks, citing potential issues in the context of GPS.
  • Another participant provides an analogy involving airplane travel to illustrate the complexities of defining velocity and synchronization, emphasizing that arbitrary synchronization could lead to contradictions in physical laws.
  • There is a mention of the need for reformulating physics if different synchronization methods are used, particularly in relation to momentum and velocity calculations.
  • Some participants express uncertainty about the reliability of certain sources discussing clock synchronization and GPS adjustments.
Participants express differing views on the validity of Einstein's clock synchronization method, with some suggesting it aligns more with Newtonian concepts under specific conditions. The discussion remains unresolved, with multiple competing perspectives on the implications and reliability of synchronization methods.
There are limitations regarding the assumptions made about the constancy of light travel time and the implications of synchronization methods on physical definitions like velocity and momentum. The discussion also highlights the potential confusion surrounding the application of these concepts in practical scenarios such as GPS.
Consider the clocks C(0)(x=0,y=0) ticking and clock C(x,y=0) stopped and fixed to read t=x/c. Source S(0,0) emits a light signal towards clock C. Arriving at its location the light signal starts clock C and we say that C(0) and C(x,0) are synchronized a la Einstein.
Is there something wrong in the statement above?
Well, you didn't explicitly state than the C(0) reads t=0 when signal was emitted. I wouldn't call that wrong, but just an omission.
clcok synchronization
Thanks. It is an omission!
T= 0
If we could sit on a photon and travel at the speed of light. Would a clock that we were carrying stop completely? I have always wondered. RC
The short answer to the question is that you can't sit on a photon.
To avoid hijacking this thread, I'd suggest that you find one of the other threads where this has been discussed, for instance google finds (physics forum "sitting on a photon")
https://www.physicsforums.com/showthread.php?t=171822
and re-ask your question there, if it hasn't already been answered to your satisfaction.
Yes and "a la Newton" I think.
'If wrong, please tell me why
If both clocks are at rest, as I understood, you can use light or sound to synchronize them. Newton would agree. You are right.
When one is moving respect to the other .. ask the experts.
I'm not quite sure if this is relevant and I'm something of an Einstein fan so I don't like to say this sort of thing: I read somewhere that there was some kind of inherent problem with Einstein's clock synchronization. There was some kind of presumption that the light takes the same time to travel both ways between the clocks. But don't quote me on this. It was about GPS and might not have been trustworthy. (I find it hard to tell what I can trust). Perhaps one of the experts can advise.
There are other reasonable reasons for using Einstein's clock synchronization. Google finds, for instance http://adsabs.harvard.edu/abs/1988AmJPh..56..811B, but if you look at the literature (including the reference list for this paper) you'll probably find that there are still some people and papers who make a rather "big deal" about clock synchronization in the literature. This has the general effect of confusing some people new to relativity, while not actually accomplishing much.
Here's my simplified "take" on the situation.
Consider taking a plane trip from New York to LA, nonstop. Ignoring take-off and landing time, you leave at 7 am, you arrive at 9 am, a two hour flight by the clock. However, by your watch, it takes you 5 hours to fly the 2000 mile distance.
On the return flight, when you leave at 7 am, you arrive at 4 pm, an 8 hour flight. But it still takes 5 hours by your watch. (I've idealized the numbers a bit, to make the example simpler).
Given that the distance is 2000 miles, is it reasonable to say that your velocity flying east from LA to NY is 2000/2 = 1000 mph, while your velocity flying from NY to LA is 2000/8 = 250 mph?
The answer, I hope, is clear - it is not "reasonable", though I suppose I should add that a sufficiently perverse and determined person can reformulate physics to work with this definition of "velocity". The point is that using this approach of allowing arbitrary clock synchronization, some reformulation of physics is needed, that this idea does not match the common, intuitive idea of what a velocity is.
For a more specific example of why physics has to be reformulated to use this definition, consider using these "velocities" in the standard equation momentum = mass * velocity. If you do so, you will incorrectly conclude that the plane flying east has much more momentum that the plane flying west. This is testable by a rather expensive, dramatic, and unrealistic experiment of crashing one plane into another, and noting where the pieces fall. It the momenta of the two planes are equal, the pieces should be symmetrically distributed over the location of the impact - if the eastward plane has over twice the momentum of the westward plane, the pieces should fall with a large eastward bias.
What you conclude is that the cocks at LA and NY are not properly synchronized, because of "time-zones", and that (in this simplified example) the velocity of the planes flying eastward and westward are the same, i.e. 2000 mi in 5 hours, or 400 mph.
How can we make this observation more formal? We can say that, at low velocities, we expect that when clocks are properly synchronized, velocity (the distance divided by the difference in times on the lab clocks) will be equal to celerity (the distance divided by the time on a clock you carry with you). See http://arxiv.org/abs/physics/0608040 for a definition of celerity and velocity (and thanks to robphy for finding this reference).
If we use any other scheme for synchronizing our clocks other than the standard one, we will notice the same effect that our airplane traveller does - that our velocity is not equal to our celerity even at low velocities. (Unfortunately, though, at low velocities, the experimental difference is small).
There is another way of putting this that is more readily tested in that it doesn't involve comparing almost equal numbers - rather than stating that velocity is equal to celerity at low speeds, one insists that the ratio of velocity to celerity not depend on direction. This is in some respects the more usual approach, it is one way of approaching what people mean when they say that space-time is isotropic, i.e. doesn't have any preferred directions.
Note that we cannot directly measure the "celerity" of light, because we cannot make a clock go at the speed of light. But by using slower-than-light signals, we can come up with a means of synchronizing distant clocks that is "fair" by imposing either the requirement that celerity be equal to velocity at low velocities, or that in general the ratio of celerity to velocity must not depend on the direction in which one travels (though it can depend on the velocity).
Furthermore, we can find (and test) that this means of synchronizing clocks yields the same clock synchrnoziation as the much-simpler-to-implement method of Einstein of using light signals.
I am affraid Newton would not agree because from his point of view time is absolute!
Regards
Thanks pervect. I've printed the arxiv article and will read it offline. The Brehme link was to an abstract, but it's a good lead, thanks. The article I was referring to is a little unreliable, judging from some of his other stuff which doesn't fit with even my mental model. So I won't raise it here. It did however talk about a 14ns GPS adjustment to the radio-defined "time now" in San Francisco and New York, which seemed quite reasonable.
Can you advise if the wikipedia articles below can be trusted? They look good, but I do have some trouble telling the difference between good science and bad.
http://en.wikipedia.org/wiki/Global_Positioning_System
http://en.wikipedia.org/wiki/Sagnac_effect
Sorry bernard, this is relevant, I'll try to explain why later. But now work calls. Must go.
As I read this, it is a one way sync. Einstein's method depends upon the over and back readings. The two clocks will not be synchronized a la Einstein
Thanks. Do you mean that c(+) is different from c(-)? Is there some experimental evidence for that?
Voltage said:
T
I don't see anything obviously wrong with the Wikipedia article (the version I looked at was
http://en.wikipedia.org/w/index.php?title=Sagnac_effect&oldid=141039015
If you want reliable technical details for the sagnac effect, I'd suggest http://relativity.livingreviews.org/Articles/lrr-2003-1/ section 2 (though it may be a bit too technical).
You can also try the last version of the Wikipedia that Chris Hillman contributed to:
http://en.wikipedia.org/w/index.php?title=Sagnac_effect&oldid=53804564
(that's not nearly as authoratative as a peer reviewed reference, but it's probably slightly more reliable than a pot-luck version of Wikipedia, which is sometimes very good and sometimes not-so-good.)
What's basically going on here is that it is impossible to synchronize all clocks in a rotating frame according to the Einstein convention, see for example another paper http://arxiv.org/abs/gr-qc/9805089. (This gets a bit technical in spots as well.). One relevant non-technical exceprt:
As an immediate consequence, it is shown that the Sagnac effect only depends on the non homogeneity of time on the platform and has nothing to do with any anisotropy of the speed of light along the rim of the disk, contrary to an incorrect but widely supported idea.
If you start synchronizing clocks pairwise using the Einstein convention, going clockwise, when you work your way around the globe the ending clock won't be Einstein synchronized with the starting clock - the Einstein synchronization process is not transitive in rotating frames when you have a complete loop.
What this basically means is that GPS time, and also TAI time, are not "fair" or isotropic synchronization schemes as I described in my previous post. Thus if you measure the speed of a plane going east-west, and going west-east, and you use GPS methods to synchronize the clocks you won't get the "true" velocity (the one that gives the momentum as a function of velocity independent of direction). For planes, the errors are very slight - at large velocities, though, the differences can become important.
If you do a thorough literature search, you will undoubtedly find that there is some confusion in the literature, i.e. not everyone agrees with Tartaglia's position. In some (but not all cases) the issue is just semantics, where people use "velocity" to be any rate of a distance coordinate with respect to a time coordinate, regardless of the physical significance (or lack of the same) of this number, i.e. they don't require that momentum be derivable solely from velocity, but allow momentum to depend on both velocity and direction. That's one of the reasons I said
No - no evidence - but much has been written on this. What Einstein needed in 1905 was a transform that would produce a null for MMx type experiments - he could have simply postulated that the over and back velocity is always constant in our universe - but instead he went further and employed a method of synchronization that embraced the idea that the one way velocity would always be measured as constant - but by the same token, he viewed it not possible to measure the one way velocity since you have an interdependence between time and distance. Einstein synchronization abrogates this quandry, and it is consistent with the experimental results even if it ultimately turns out that the two "one way" speeds are in fact unequal
Thanks. What is then your final answer to my thread which initiated the discussion?
Your assumption will recover the LT when you eliminate the uncertainty in the distance measurement...then the clocks will be synchronized a la Einstein.
It may be worth noting that the "over and back" convention is a special case of requiring that the speed of light is independent of path. One observer (stationary) may see the light following the same path in both directions, but another (moving) observer will see the two paths as different. In special relativity, the speed is always the same.
  • · Replies 42 ·
  • · Replies 21 ·
  • · Replies 25 ·
  • · Replies 20 ·
  • · Replies 20 ·
  • · Replies 47 ·
