Undergrad Closed-form solution for an integral
The discussion centers around finding a closed-form solution for the integral \(\int_0^z\frac{1}{1+z-x}\frac{1}{(1+x)^K}\,dx\) for positive integer \(K\) and \(z \geq 0\). While Wolfram Alpha provides an indefinite integral solution involving the Hypergeometric function, users express concerns about referencing this in academic work without a systematic derivation. Suggestions include using partial fraction decomposition to simplify the integral, enabling the calculation of coefficients through linear equations. The conversation highlights differing expectations across fields regarding the necessity of citing integral solutions and the acceptable practices for proving their correctness. Ultimately, the importance of verifying results and providing reliable references is emphasized.
EngWiPy
Hello all,
Is there a closed form solution for the following integral
for a positive integer ##K\geq 1##, and ##z\geq 0##? I searched the table of integrals, but couldn't find something similar.
Thanks in advance for any hint
Thanks. I tried to compute the definite integral from 0 to 1, and from 0 to 0.5, but gave me "Standard computation time exceeded ...". I think this is because it is an online version of Mathematica with limited resources. I guess I can use the indefinite integral to find the definite one, but this is for an academic paper, and I need to reference the solution. I don't think saying that Mathematica gave this solution is acceptable, isn't it?
    No but you should be able to prove that the integral is correct by differentiating it and matching it to what you started with. You will probably need to use some facts about Hypergeometric numbers to complete that, but I imagine the ones you need will be available in the above-linked wiki article on those numbers. There are formulas for differentiation of the function wrt its fourth argument, which will be needed, here.
Likes FactChecker
andrewkirk said:
  1. No but you should be able to prove that the integral is correct by differentiating it and matching it to what you started with. You will probably need to use some facts about Hypergeometric numbers to complete that, but I imagine the ones you need will be available in the above-linked wiki article on those numbers. There are formulas for differentiation of the function wrt its fourth argument, which will be needed, here.
I am sorry, but this means that I somehow found the solution, and then proved it is the correct solution backwardly. Reviewers will ask how I obtained the solution in the first place. I think it will be hard to convince them without a forward solution.
I was thinking that the above integral can be written as
<br /> A\int_0^z(1+z-x)^{-1}\,dx +\sum_{k=1}^KB_k\int_0^z(1+x)^{-k}\,dx<br />
using partial fraction decomposition. The coefficients can be found by solving ##K+1## linear equations, and I think the resulted integrals have solutions.
Likes Stephen Tashi
What journal are you writing for? I can't think of any journal that sets that standard. What reviewers are concerned about are that mathematical results are proved to be correct, not how you came up with the result. Differentiation and matching constitutes a proof that the integral is correct, and that is all that any reviewer I have ever known would be concerned with.
Likes FactChecker and EngWiPy
I have reviewed papers in my field, and if encountered with a similar situation, I probably would question the method, because it is not systematic and doesn't provide guidance on how to solve the integral. It seems like guessing, then testing the guess, which, although correct, isn't systematic.
That criticism is understandable if your field investigates "How to solve integrals". However, papers on many scientific topics simply state solutions to integrations because they are a side issue. They often leave verification of the integrations to the referees and readers.
Likes FactChecker
I don't know if this is different across fields, but in my field I haven't seen a paper that doesn't reference a solution to an integral, if it isn't derived in the paper itself, and I have learned through the years to reference any equation that I am not deriving. Usually researchers reference the Table of Integrals if the solution is there, which is a reliable reference to reviewers. You don't have to show how to reach to the solutions, but you need to cite a reliable reference.
It's very common to just say that a result can be verified. Integrals, solutions to differential equations, etc. are full of solutions that are just known to be true due to a "lucky" coincidence. All you are responsible for is due diligence in showing that your statements are true and verifyable.
Likes andrewkirk
Interesting. I was talking the other day with a researcher with a math background, and he says the same thing (he uses Mathematica to find solution to integrations, without even verifying). It seems that this is a common and acceptable practice in mathematics and maybe in physics as well.
using partial fraction decomposition. The coefficients can be found by solving ##K+1##" linear equations,
Maybe we can build up the solutions to the equations rather than starting from scratch for each value of ##k##
Begin with ##k = 1## by finding ##A,B## that give the expansion
##f(x) = \frac{1}{(1 + z - x)(1+x)} = \frac{A}{1+z-x} + \frac{B}{1+x}##
##A = B = \frac{1}{z+2}##
Then
## \frac{1}{(1 + z - x)(1+x)^2}= f(x)\frac{1}{(1+x)} = \frac{A}{(1+z-x)(1+x)} + \frac{B}{(1+x)(1+x)} ##
## \ = A ( \frac {1}{(1+z-x)(1+x)}) + \frac{B}{(1+x)^2} ##
## \ = A (\frac{A}{(1+z-x)} + \frac{B}{(1+x)} ) + \frac{B}{(1+x)^2}##
##\ = A^2 \frac{1}{1+z-x} + AB\frac{1}{1+x} + B \frac{1}{(1+x)^2}##
By a similar process
##\frac{1}{(1+z-x)(1+x)^3} = A^3 \frac{1}{1+z-x} + A^2B \frac{1}{1+x} + AB\frac{1}{(1+x)^2} + B\frac{1}{(1+x)^3}##
Likes EngWiPy
Then
Very elegant. In general we can write
\frac{1}{(1+z-x)(1+x)^k} = \frac{A^k}{(1+z-x)}+B\sum_{m=1}^k\frac{A^{k-m}}{(1+x)^m}
All we have to calculate in this case is just ##A## and ##B##. Thanks
  • · Replies 21 ·
