Closed under addition and closed under scalar
Closed under addition and scalar multiplication refers to properties of a subset A within a vector space, specifically R^2 in this context. A is closed under addition if the sum of any two elements in A also belongs to A, while it is closed under scalar multiplication if multiplying any element by a scalar results in another element in A. The set A, defined by the condition x^2 + y^2 ≤ 1, represents a disk in the plane, and to determine if A is a subspace, it must meet the criteria of being closed under addition, closed under scalar multiplication, and containing the zero vector. The discussion clarifies that simply having the condition x^2 + y^2 ≤ 1 does not guarantee these properties, thus A is not a subspace of R^2. Understanding these concepts is crucial for grasping the structure of vector spaces and their subsets.
negation
Could someone explain to me about what closed under addition and closed under scalar multiplication means? I have a patchy idea of what it is but how does it relates to A = {(x,y) | x^2 + y^2 <= 1}?
What does A stands for? What does the language implies?
Edit: My interpretation: Let's suppose there exists a field k with R^n where n = 2) and A is a subset of the field k.
An element is closed under addition iff an element, uA, and, vA such that
u^2+v^2 = <=1.
If u^2+v^2 <=1, then, u and v is a subset of A.
In other words, you are considering ##R^2## as a vector space over the reals. Addition means ##(u,v)+(x,y) = (u+x,v+y)## and scalar multiplication means ##t(x,y) = (tx,ty)##, the usual vector operations in ##R^2##.
u^2+v^2 = <=1.
You have a very confused interpretation. You don't talk about whether an element is closed under addition, you talk about whether the subset ##A## is closed under addition. That is, if ##(a,b)## and ##(c,d)## are in ##A##, is ##(a,b)+(c,d)## always in ##A##? If so, ##A## is closed under addition. Similarly, if ##(x,y)\in A## is ##t(x,y)\in A## or not.
How does x^2 + y^2 relates the the closed addition and scalar multiplication?
negation said:
How does ##x^2 + y^2\color{red}{\le 1}## relates the the closed addition and scalar multiplication?
That's how you tell if ##(x,y)\in A##. So if you add two elements in ##A## is the result in ##A##?
So x^2 + y^2 <=1 is a condition. If vector u and vector v both of which are elements of S where S is a set of vectors and if u+v <= 1 then it is closed under addition.
And if it fulfils 2 other necessary conditions- namely, closed under scalar multiplication and where 0 vector is an element of S then S is a subspace.
Yes, this is the condition by which you can determine whether a vector <x, y> is a member of set A (the name of the set from post #1). S is not mentioned in post #1.
No, that isn't it. If u and v are members of A, and if u + v is also in A, then A is closed under vector addition.
The condition, as you call it, is how you can tell whether a given vector is in set A.
Just to be clear, assuming that u is in A, and t is a scalar, if tu is also in A, then A is closed under scalar multiplication.
Is it the same thing to say A closed under addition, closed under scalar multiplication and has zero vector and A is the subspace of a vector space?
Not quite. You need some ifs and a then.
For a set A, a subset of a vector space, if
1. A is closed under vector addition, and
2. A is closed under scalar multiplication, and
3. The zero vector is an element of A,
Then A is a subspace of the vector space. (Whatever vector space we're working with.)
  • · Replies 18 ·
