Coal needed to produce 100000 BTU/s
  • Thread starter Thread starter noxnoxmox
    Coal
The discussion revolves around the amount of coal required to produce a heating output of 100,000 BTU/s in a typical house. Participants explore the energy density of coal and its implications for heating requirements, with a focus on practical applications in residential heating.
  • Technical explanation, Debate/contested, Experimental/applied
  • One participant questions the heating output of 100,000 BTU/s, suggesting that 100,000 BTU/hr is more typical for a medium-large house in a cool climate.
  • Another participant, a contractor, confirms that 100,000 BTU/hr is a normal heating requirement for houses in Maine, citing a specific energy density of 12,000 BTU/lb for coal.
  • A different participant notes the variability in the specific heat of coal, mentioning that high-quality Pennsylvania anthracite can have an energy density as high as 17,000 BTU/lb, while lower-quality Texas brown coal may only provide 2,500 BTU/lb.
Participants do not reach a consensus on the heating output of 100,000 BTU/s versus BTU/hr, and there are differing views on the energy density of coal based on its type.
The discussion highlights the dependence on specific types of coal and their respective energy densities, which may vary significantly. There is also an assumption that the heating output is intended for a residential setting, but this is not explicitly confirmed.
noxnoxmox
how much coal is required to produce 100000 BTU/s in a typical house?
I have been looking and looking with no leads on it
need help please
I am a plumbing, heating, and cooling contractor in Maine. 100,000 btu/hr is normal for a house up here with a -10 design temp. We use 12,000 btu's per lb for bulk or bag coal. It has always worked for us.
The specific heat of coal varies all over the map. Really good Pennsylvania anthracite (virtually unavailable now) was as high as 17,000 btu/lb, while some Texas brown coal is as low as 2500 btu/lb. Be sure to get the correct specific heat for the coal you plan to use.
  • · Replies 25 ·
  • · Replies 32 ·
  • · Replies 52 ·
9K
