Coefficient of friction and forces proof
The minimum force F required to move a box of weight W on a horizontal surface, when applied at an angle theta, is derived as F=(mu*W*sec theta)/(1-mu*tan theta). This formula incorporates the coefficient of static friction mu and utilizes trigonometric functions such as secant and tangent. The discussion emphasizes the importance of correctly identifying the normal force and the frictional force acting on the box. Participants clarified the relationships between these forces, leading to the correct formulation of the problem.
  • Understanding of static friction and its coefficient (mu)
  • Knowledge of trigonometric functions, specifically secant and tangent
  • Familiarity with Newton's laws of motion
  • Ability to analyze forces in two dimensions
  • Study the derivation of forces in inclined planes and their applications
  • Learn about the implications of static vs. kinetic friction in real-world scenarios
  • Explore advanced topics in dynamics, focusing on force decomposition
  • Investigate the role of angle of application in force calculations
Students in physics, particularly those studying mechanics, engineers analyzing force applications, and educators seeking to clarify concepts of friction and force interactions.
physfan
A box of weight W is pushed by a force F on a horizontal floor (the diagram below shows the force on the box is at an angle theta to the horizontal)
If the coefficient of static friction is mu, show that the minimum value of F that will move the crate is given by:
The only maths needed i think is trig functions such as sec=1/cos, 1=sin^2+cos^2 etc.
For physics, I have called the frictional force acting against the box fr and the reaction against the horizontal plane R. fr=mu*R is the only equation I could find with the exception of the equations that are results of Newton's thid law (which are listed in my attempted solution)
Horizontally I worked out F*cos theta=fr=mu*R
Vertically, F*sin theta=W=n (not sure which values to use so I plugged them all in there)
1st attempt: R is rective force and W=mg so R=W.
fr=mu*W
F*cos theta=mu*W
F=(mu*W)/cos theta
But obviously the result is more complicated than that so I then tried:
fr=R*tan theta (taken from previous class notes but I don't know if this value is suitable for this problem...)
F*sin theta=W=n
F*sin theta*tan theta=mu*W=(F*sin^2 theta)/cos theta
F=(mu*W*cos theta)/sin^2 theta (from rearranging the above line)
F=(mu*W*cos theta)/(1-cos^2 theta) then I just trailed off...
I have made many more attempts but have rubbed them out as they were yet more unsuccessful...
Please help!
Is it above the horizontal or below?
:confused: Iguess that by R you mean the normal force. This is not standard notation.
No. You must set the net force along y equal to zero. You can't set the three forces eqaul to one another!
the normal force is certainly not equal to the weight here since there is another force with a y component.
Yeah for R I do mean the normal force, I've heard it as both R and n depending on the teacher... I prefer n to be honest but my teacher today is an R person.
Looking at y now I'm thinking F*sin theta - n = 0 (hence F*sin theta = n) but that doesn't seem to get me any further than my previous attempts...
Oh and the angle theta is above the horizontal.
Oh hang on, F*sin theta + W = n doesn't it... sorry, I don't know why I didn't write that before. Blonde moment... I'll have another go.
Right, I'm now getting:
For y: F*sin theta+W - n=0
so F*sin theta+W=n
For x: F*cos theta - mu*n=0
so F*cos theta = mu*n
Substituting in the first equation for n:
F*cos theta=mu*(F*sin theta+W)
F*cos theta=mu*F*sin theta+mu*W
F*(cos theta - mu*sin theta)=mu*W
so F=(mu*W*cos theta)/sin^2 theta
and then the trail goes cold again...
This does not look quite right (unless some of your quantities there are negative)
The way to do it is to start with \sum F_y = m a_y
In your case a_y is zero. Therefore the net force along y is zero. Therefore
F \sin \theta + n - mg = 0
I had never heard of "R" for a normal. In what country are you, just out of curiosity?
I'm from England, there's just one teacher I have who calls it the "reaction" to the plane.
So if we take the direction of n to be positive, why is Fsin theta also positive... isn't that acting in the opposite direction? i.e. pushing down, therefore adding to the weight?
I obtain the equation you quoted except that I have a division by 1+ \mu \tan \theta instead of with a minus sign like you gave. Are you sure you typed the rigt formula?
You mean the right result?
Yes, it's definitely supposed to be 1-mu*tan theta on the bottom...
The force must be acting downward, so that should be:
-F \sin \theta + n - mg = 0
n = F \sin \theta + mg
Yup, thought so, but I'm still not getting the right result...
I used n=Fsintheta + mg earlier in post #6... which shows my latest (unsuccessful) attempt. I can't really see how to carry it on.
so F*sin theta+W=n
OK.
OK.
Good.
Huh?
Just divide by (cos theta - mu*sin theta) and you're done. (Almost.)
Doc Al said:
OK.
Huh?
Sorry! My notes are rather messy and I typed out the wrong bit.
I meant:
F(cos theta - mu*sin theta)=mu*W
so F=(mu*W)/(cos theta-mu*sin theta). which is where I got stuck but if that's right I'll have another look first.
Thanks!
You are one small step away from the final answer. Hint: What do you have to do the denominator to make it the way you want?
Oh yeah you just divide throughout by cos theta!
Right, got it, thanks again
(Edit: and for the record, I did that before I saw your post...)
  • · Replies 24 ·
