Coefficient Of Friction (Circular Motion)
The discussion focuses on the coefficient of friction in circular motion, distinguishing between static and kinetic friction. Static friction applies when an object is stationary relative to another surface, while kinetic friction occurs when there is relative motion. The confusion arises when static friction is used to calculate maximum speed in circular motion, despite it typically being associated with stationary objects. It is clarified that in cases like a car tire, the contact surface can remain stationary while the object moves, necessitating the use of static friction. Additionally, the topic of rolling resistance in ball bearings is introduced, highlighting the need to treat it as a separate type of friction.
Air
This is the concept that I am understanding for coefficient of friction. Static coefficient of friction is one which refers to friction which is considered when the object is stationary relative to the other contact object. Kinetic coefficient of friction is one which refers to the friction which is considered when the object is in motion relative to the other contact object.
But, I've come across many question in circular motion which talk about static coeffient of fricition even though it's asking about calculating maximum speed. If static coeffient of friction is when the object is stationary then why is it used to calculate speed, acceleration in circular motion (Surely, we consider coefficient of kinetic friction)? Does the concept differ in circular motion?
Kinetic friction only occurs when contact surfaces slip against each other--thus the surfaces are in relative motion. Sometimes an object as a whole can be moving, yet the contact surface will not move with respect to the ground. For example, a car can move while the part of the tire in contact with the ground is always at rest with respect to the ground. As long as there's no slipping (or skidding) the only friction you need to worry about is static friction.
Feel free to give a specific problem that we can look at in detail.
As for a specific problem, what about a ball bearing for example. I have a wheel rim attached to an axle via a ball bearing. How would I calculate the friction between the bearings? Is that Kinetic friction?
The ball bearing will roll on the axel and on the housing - no slipping so it is STATIC friction.
Right. So if the wheel rim is free spinning (in the air), what are the forces acting against it? I now assume there is static friction between the housing and axle, I would also think there is some form of rolling resistance between these 2 components as well?
Bearings are pretty different from the OP question. Ball and roller bearings have to be treated in terms of their rolling resistance, which is best treated as a separate kind of friction. See, for example,
http://evolution.skf.com/zino.aspx?articleID=14959
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 16 ·
  • · Replies 18 ·
  • · Replies 23 ·
