Coefficient of Friction problem
The discussion revolves around a physics problem involving a waterpark waterslide where a 120 kg man slides down a frictionless slide before encountering friction on a ramp. Due to a management decision, the water is turned off, creating friction that affects his speed as he leaves the ramp. Participants discuss using Newton's second law and free body diagrams to calculate the man's acceleration and velocity at the ramp's end, as well as the necessary steps to determine the coefficient of friction. There is confusion regarding the calculations of speed before and after the ramp, with one participant reporting a velocity of 22.1 m/s upon leaving the ramp, which raises questions about its accuracy. The conversation highlights the need for clarification on calculating vertical acceleration and the effects of friction on energy loss.
tbone413
An attraction at a waterpark includes a straight waterslide 20m long at an angle of 34 degrees above the horizontal. The waterslide ends in a ramp 5 m long at an angle of 45 degrees above the horizontal. People sliding down the slide land in a small pool just past the end of the ramp. The waterslide is kept frictionless by spraying fine streams of water onto it through several nozzles located along the length of the slide.
Unfortunately, a poor management decision to conserve water at the water park results in the water being turned off just as a 120 kg man enters the ramp, so that the last 5m of his trip on the slide is no longer frictionless. The man flies off the ramp, misses the pool and lands on the pavement a horizontal distance of 12m fro the end of the slide. What is the coefficient of friction between the man and the waterslide?
F(x) = -Fk = ma(x)
F(y) = n - mg = 0
n-mgcos(theta) = 0
Ff(force of friction) + mgsin(theta) = ma(up)
Well I am not really sure how to attempt this problem at all, its extra credit and we haven't quite learned this material yet. I do know though that its a Newtons second law problem and that when going up the ramp the frictional force will cause the acceleration to decrease. I also know that I have to use a FBD to figure out the acceleration and velocity of the man at the moment he hits the ramp, and then solve for the coefficient of friction. However I am not quite sure what steps to take. So if someone could maybe walk me through their thought process id Really appreciate it.
Work out the horizontal and vertical components of his speed at the start of the friction part ( using either conservation of energy or constant vertical accelearation)
Then work out what speed he must have left the ramp to reach the crash point - this is just the standard cannon ball firing question.
Then you have how much speed ( and therefore energy ) he lost to friction.
Since energy is force * distance you can work out the average force, and with his weight to give you the normal force - you have the coefficent of friction.
Im not quite sure how you would find the components of his speed using the constant vertical acceleration. can you clarify a bit more?
If you neglect friction the only forces acting are his weight, so you can calculate the vertical accelaration of an object down an inclined plane just by knowing 'g' and the angle
ahh ok. that makes sense.
I came up wth 22.1 m/s for his velocity he left the ramp at, and 11.54 m/s for his velocity before he left..which doesn't make sense.
Are either of those numbers similar to what you got?
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
