What is the formula for calculating the coefficient of lift for an airfoil?
  • Thread starter Thread starter thetexan
    Coefficient Lift
The coefficient of lift (CL) for an airfoil is not derived from a single formula but rather involves complex calculations based on various factors such as angle of attack (AOA), camber, and thickness. The lift equation is expressed as L = CL * (rho * 1/2 * V^2 * S), where L is lift, rho is air density, V is velocity, and S is surface area. To determine CL, methods such as wind tunnel testing, computational fluid dynamics (CFD), or Joukowsky transforms are employed. The integration of pressure coefficients across the airfoil surface is essential for accurate lift and drag calculations, indicating that experimental data is crucial for establishing CL values.
  • Understanding of aerodynamic principles, particularly lift and drag.
  • Familiarity with the lift equation and its components (L, rho, V, S).
  • Knowledge of computational fluid dynamics (CFD) techniques.
  • Basic grasp of airfoil design characteristics, including camber and thickness.
  • Research methods for measuring airfoil performance in wind tunnels.
  • Explore computational fluid dynamics (CFD) software for airfoil analysis.
  • Study the Joukowsky transform and its application in aerodynamics.
  • Read "Theory of Wing Sections" by Abbott and Von Doenhoff for in-depth understanding of airfoil theory.
Aerospace engineers, aerodynamicists, and students studying fluid dynamics or aerodynamics will benefit from this discussion, particularly those focused on airfoil performance and lift calculations.
thetexan
TL;DR
Elements of Cl
A C of L curve for a particular airfoil is calculated based on what?
I know AOA is a part of it but is there a formula for CL itself? For example...
CL= L / rho * 1/2 * V^2 * S
Which is fine.
but...
L = CL * rho * 1/2 * V^2 * S
gets a value for CL from somewhere, right?
I assume it’s calculated from some formula based on shape or camber and thickness and other factors and AOA.
if that’s true does anyone know the formula and the elements of the calculation?
for example the formula for lift includes the elements of density, velocity, and surface area and CL. What I’m looking for are the elements used in the calculation of CL itself. If that's possible.
thanks,
Tex
There are a few ways to get the pressures on the different parts of an airfoil. You could mount a model in a wind tunnel; You could use a finite element method; or a Joukowsky transform to turn the airfoil into a cylinder with rotation of the flow. https://en.wikipedia.org/wiki/Joukowsky_transform
Once the pressures on the surface are known they can be resolved into vertical and horizontal components and integrated over the profile, to give the lift and the drag.
Ultimately, the most common way would be integrating the pressure coefficient across the surface and then splitting the resultant into its vertical and horizontal components. Still, you need to calculate ##C_p## to do that, and in general there is no "formula" to calculate these sorts of things. You have to either perform CFD of some kind, use various "simpler" theories for approximate answers, or measure it experimentally. Also note, I used the word "simpler" instead of "simple" here. None of these things are simple enough to allow calculation from a formula.
So is the only way CL is determined on a particular airfoil by experimentation? Then those numbers made into a graph?
Is there not a CL formula like the lift formula?
I was under the impression (I don’t remember where I got it) that there was a formula that involved camber ratios and other stuff.
Tex
9K
