Coefficient of Restitution & Collisions
The discussion revolves around solving a mechanics problem involving two spheres in a circular groove, focusing on their velocities after the first collision and the timing of the second collision. The coefficient of restitution, denoted as e, plays a crucial role in determining the velocities of the spheres post-collision. After the first collision, the velocities of spheres A and B are derived as Va = (1-e)/2 and Vb = (1+e)/2. The correct timing for the second collision is confirmed to be t = T(2+e)/e, which incorporates the initial time T. The key takeaway is the importance of using relative velocity to simplify the calculations.
wanchosen
Hi there,
I have been struggling with this problem for a while. It's an A-Level Mechanics problem.
A smooth groove in the form of a circle of radius a is carved out of a horizontal table. Two small spheres, A and B, lie at rest in the groove at opposite ends of a diameter. At time t = 0, the sphere A is projected along the groove and the first collision occurs at time = T. Given that e is the coefficient of restitution between the spheres, find the velocities of A and B after the first collision. Hence, or otherwise, show that the second collision takes place at time
t = T(2+e)/e.
I have included my solution of the first part in Solution1.txt and can confirm the answers. It's the last part that I have been unable to do.
After collision 1, B is traveling faster than A and I am assuming they are both traveling in the same direction (I have tried assuming A rebounded but still can't get the answer!)
So distance traveled by A before the second collision will be
(Va is the velocity after the first collision, Sa is the distance traveled by A before 2nd impact.)
Sa = t x Va
The distance traveled by B before impact will be the circumference + Sa
Sb = 2πa + Sa
where Sb also equals
Sb = t x Vb
I've substituted the velocities for A and B but still come up with
t = 2T/e
Can somebody help?
t = T(2+e)/e.
t = 2T/e
Hi wanchosen! :smile:
But 2T/e is right … add the original T, and you get T(2+e)/e. :rolleyes:
btw, you're making this needlessly complicated …
Once you've obtained Vb = V(1+e)/2, Va = (1-e)/2,
all you need to know is Vb - Va, which is eV.
It's only the relative velocity that matters! :smile:
Hi tiny-tim,
Thank you so much for that. That makes sense now! It was much easier working with the relative velocity! I completely forgot about adding the original time T to travel to the first collision! Thanks again.
  • · Replies 18 ·
