Coefficient of restitution of a ball bouncing down steps
The discussion focuses on calculating the coefficient of restitution for a ball bouncing down a flight of steps. The ball is kicked horizontally from the top step and lands in the middle of each subsequent step. The coefficient of restitution is defined as the ratio of the speeds before and after impact, and the problem requires understanding the ball's motion dynamics, including horizontal and vertical velocity components. Key insights include the importance of sketching the scenario and analyzing the motion after each bounce to determine the coefficient for all steps involved.
  • Understanding of the coefficient of restitution in physics
  • Basic principles of projectile motion
  • Knowledge of kinematics, specifically vertical and horizontal motion
  • Ability to create and interpret motion diagrams
  • Study the principles of projectile motion in detail
  • Learn how to calculate the coefficient of restitution using real-world examples
  • Explore kinematic equations for vertical and horizontal motion
  • Practice drawing motion diagrams for various projectile scenarios
This discussion is beneficial for physics students, educators, and anyone interested in understanding the dynamics of bouncing objects and the application of the coefficient of restitution in real-world scenarios.
Daniel1992
A small ball is placed at the edge of the top step of a flight of steps. Each step has identical
dimensions. The ball is kicked horizontally, perpendicular to the edge of the top step. On its first and second bounces it lands exactly in the middle of the first and second steps down from the top. Find the coefficient of restitution between the ball and the first step.
The ball continues bouncing down the steps hitting the middle of each successive step. What is the coefficient of restitution between the ball and the remaining steps?
I have been given the above problem to work. I am not sure where to start. All I know is that the coefficient of restitution is the ratio of speeds before and after the impact. Can anyone point me in the right direction?
The following questions should give a good start. Try to use them one by one, and see if you can continue yourself at some point.
Did you draw a sketch? This should include labels for some relevant parameters, like the step height and length.How does the motion of the ball after the initial kick look like? In particular, how long does that last?What do you know about the horizontal velocity component? How is that related to the motion after the first bounce? How is that related to the vertical component?
