Coefficient of Rolling Friction
19 replies · 21K views
stokes
Two bicycle tires are set rolling with the same initial speed of 3.00 along a long, straight road, and the distance each travels before its speed is reduced by half is measured. One tire is inflated to a pressure of 40 and goes a distance of 17.2 ; the other is at 105 and goes a distance of 92.3 . Assume that the net horizontal force is due to rolling friction only and take the free-fall acceleration to be = 9.80 .
What is the coefficient of rolling friction for the tire under low pressure?
I found the acceleration to be -0.19 I am stuck at that part I don't know what to do from there.
Ive tried that but Fnet=ma... they don't give mass in the problem. I can't find the coefficient without mass. I am really stuck...I know I have to use Newtons second law but I don't know how to start...
You may not need to know the mass. What's the formula for the friction force, which is given as Fnet in this problem?
Friction force= coefficient of friction * Normal force...?
Hmmm that is what I am stuck on calculating normal force. Is there a way to calculate normal force with the information provided?
Fn= 0?
Force of gravity. 9.8m/s^2
Sorry I don't really know...
I believe that's where I am stuck... I can't seem to continue from there. I would be missing the friction force to calculate the coefficient of friction.
No, you already stated what the friction force, F_f is: it's the coef of friction, u, times the normal force, N, that is F_f = Fnet = u*N, and since N=mg, then the friction force is u*mg. And since F_net = ma, can you now solve for u?
Thank you for your help. I don't know why I couldn't put that all together. Thanks again.
