onemind
- 28
- 0
But it never actually gets to the limit.
Issues with the proposed calculus-based solution
A suggested problem with using calculus to try to solve Zeno's paradoxes is that this only addresses the geometry of the situation, and not its dynamics. It has been argued that the core of Zeno's paradoxes is the idea that one cannot finish the act of sequentially going through an infinite sequence, and while calculus shows that the sum of an infinite number of terms can be finite, calculus does not explain how one is able to finish going through an infinite number of points, if one has to go through these points one by one. Zeno's paradox points out that in order for Achilles to catch up with the Tortoise, Achilles must first perform an infinite number of acts, which seems to be impossible in and of itself, independent of how much time such an act would require.
Another way of putting this is as follows: If Zeno's paradox would say that "adding an infinite number of time intervals together would amount to an infinite amount of time", then the calculus-solution is perfectly correct in pointing out that adding an infinite number of intervals can add up to a finite amount of time. However, any descriptions of Zeno's paradox that talk about time make the paradox into a straw man: a weak (and indeed invalid) caricature of the much stronger and much simpler inherent paradox that does not at all consider any quantifications of time. Rather, this much simpler paradox simply states that: "for Achilles to capture the tortoise will require him to go beyond, and hence to finish, going through a series that has no finish, which is logically impossible". The calculus-based solution offers no insight into this much simpler, much more stinging, paradox.
A thought experiment used against the calculus-based solution is as follows. Imagine that Achilles notes the position occupied by the tortoise, and calls it first; after reaching that position, he once again notes the position the turtle has moved to, calling it second, and so on. If he catches up with the turtle in finite time, the counting process will be complete, and we could ask Achilles what the greatest number he counted to was. Here we encounter another paradox: while there is no "largest" number in the sequence, as for every finite number the turtle is still ahead of Achilles, there must be such a number because Achilles did stop counting.
It's not very stinging at all; this statement is flawed. If Achilles counted as stated in the article, then he finished counting; he went through every natural number.wikipedia said:The calculus-based solution offers no insight into this much simpler, much more stinging, paradox.
If Achilles counts as in the Wikipedia article, then Achilles said every natural number.arunbg said:Hurkyl, I don't quite understand what you are trying to say, can you please clarify a bit more.
If Achilles finished counting, he must have stopped at some number, but there seems to be no end to the counting process, what is wrong with the paradox?
What does it matter if any of its partial sums are unequal to the limit?
onemind said:I think Hurkyl has been blinded by science and can't come to terms that this really is a paradox outside his ability to explain hence the never ending tedious explanations.
So what is the point of this thread?
You have asked a question in a mathematics forum, but your disposition is that of one whom refuses mathematical proof.
I mean, is math in this case just a simplification in order to deal with this problem but doesn't represent the true physical reality of movement?
No it doesn't: it only goes for 1 second. (Given the numbers I stated above)onemind said:Because that is the whole point of the paradox. It never gets there because it goes for eternity
Did you consider the possibility that I just might know what I'm talking about?I think Hurkyl has been blinded by science and can't come to terms that this really is a paradox outside his ability to explain hence the never ending tedious explanations.
Like most of the variations, the devil is in the [omitted]details. It says nothing about "how far", or what "some period of time" is.It will then take Achilles some further period of time to run that distance, in which said period the tortoise will advance farther;
I can't fix your problems by myself: you have to cooperate.onemind said:Of course, but after listening you give the same explanation over and over without considering where i am coming from i came to the conclusion that you are blinded by science.
I think i will go with Einstein on this one rather than Hurkyl.
the distinction between the duration of an interval of time and the number of points in an interval of time has come up several times in this thread, brought up by several people. And yet you have not indicated you recognize they are different, nor have you indicated that you think they are the same.
onemind said:..
I disagree with cane toad that this concept is merely semantic but of course i agree that it is not useful.
Ok, but which?
onemind said:Zenos paradox. I don't see what is semantic about contemplating finite infinity which is basically what zenos paradox is minus the greek analogy of achilles and the turtle.
Wikipedia:
Zeno's arguments are perhaps the first examples of a method of proof called reductio ad absurdum, also known as proof by contradiction.
yet you used the terminology "continuous/continuity"...would you care to elaborate on your understanding of this terminology, and how you would describe "physical/reality" concept "motion"?
The paradox is childish, but the reflections it sparked are not
It will then take Achilles some further period of time to run that distance, in which said period the tortoise will advance farther; and then another period of time to reach this third point, while the tortoise moves ahead.
Aristotle pointed out that as the distance decreases, the time needed to cover those distances also decreases, so that the time needed also becomes increasingly small. Such an approach to solving the paradoxes would amount to a denial that it must take an infinite amount of time to traverse an infinite sequence of distances.
In this capricious world nothing is more capricious than posthumous fame. One of the most notable victims of posterity's lack of judgement is the Eleatic Zeno. Having invented four arguments all immeasurably subtle and profound, the grossness of subsequent philosophers pronounced him to be a mere ingenious juggler, and his arguments to be one and all sophisms. After two thousand years of continual refutation, these sophisms were reinstated, and made the foundation of a mathematical renaissance...
— Bertrand Russell, The Principles of Mathematics (1903)1
Before 212 BCE, Archimedes had developed a method to derive a finite answer for the sum of infinitely many terms that get progressively smaller. Theorems have been developed in more modern calculus to achieve the same result, but with a more rigorous proof of the method. These methods allow construction of solutions stating that (under suitable conditions) if the distances are always decreasing, the time is finite.
Only the parts of the story that support the paradox are adequately stated. It doesn't say that Achilles has to stop at each point, which is left as an implication(?). If he doesn't than there is no paradox.
The reaction time of Achilles each time he stops isn't specified, so:
onemind said:What in the world are you talking about mate? Reaction time of achilles? I think your reading too much into the story.
Forget the story and look at it the way in terms of point A to B as i outlined in the first post.
Talk about disingenuous people using ideas to suit them.![]()
Well, (actual) paradoxes aren't matters of opinion: either you have, or you have not exhibited an argument that derives a contradiction from a specified set of hypotheses. What hypotheses do you think lead to a paradox? What contradiction is derived? What is the proof?arunbg said:But although the total time taken to catch up is finite(which is real worldish), it takes him an infinite no. of steps(which is non-real worldish), this is the heart of the paradox today. I believe this still remains a paradox.
What is the contradiction? What statement is both proven and disproven?neurocomp2003 said:the paradox: there are infinite amount of steps(action) to get to the bounding conditions(time/space bounds)?
