Graduate What kind of coherence do we have in the ground state of a harmonic oscillator?
The discussion centers on the coherence properties of the ground state of a harmonic oscillator in quantum mechanics. It clarifies that while coherent states are eigenstates of the annihilation operator, the ground state itself does not exhibit coherence or a definite phase. The relationship between the uncertainty in position and momentum is highlighted, emphasizing that the ground state achieves the minimal uncertainty of ΔxΔp = ħ/2. Additionally, the conversation touches on the nature of coherent states as quasi-classical and their relevance in describing thermal sources and photon behavior in beam splitter experiments. Ultimately, the ground state serves as a degenerate case of coherent states, with coherence becoming more pronounced as the excitation level increases.
LagrangeEuler
I am confused. In harmonic oscillator problem in quantum mechanics eigenstates of operator ##\hat{a}## are called coherent states. So we practically get Gaussian. In problem of quantum linear harmonic oscillator we have phonons ##|n \rangle##. In case of laser we have photons ##|n \rangle##. Could you explain me what kind of coherence do we have in ground state of harmonic oscillator?
Likes vanhees71
In a laser many excited atoms drive (ideally) a single mode of the radiation field. A radiation field mode is an harmonic oscillator. The ##a## and ##a^\dagger## operators are the quantum equivalent of the wave/mode amplitude. With many atoms driving a mode a laser doesn't produce a ##\vert n\rangle## state but rather something much closer to a coherent state, ##a\vert \alpha\rangle = \alpha\vert \alpha\rangle##. The reason for this is that all the excited atoms are coupled through the common field mode.
Yes, and stimulated emission is a coherent process, i.e., you get a pretty coherent em. wave with well defined phase rather than Fock states with a definite photon number. This coherence it is which makes lasers such a great invention!
For me is hard to understand for example in case of LHO ##\Delta \hat{x} \Delta \hat{p}_x=(n+\frac{1}{2})\hbar ##. So if we have third exited state then ## \Delta \hat{x} \Delta \hat{p}_x=\frac{7}{2} \hbar## and in case of ground state ## \Delta \hat{x} \Delta \hat{p}_x=\frac{1}{2} \hbar##. What means that ## \Delta \hat{x} \Delta \hat{p}_x## is larger in one state then in another?
Well, it tells you that only the ground state of the harmonic oscillator and its unitary transformations (the coherent states are unitary transformations of the ground state!) lead to the "minimal space-momentum uncertainty", i.e., to ##\Delta x \Delta p =\hbar/2##. The uncertainty relation tells you that for any state ##\Delta x \Delta p \geq \hbar/2##.
Likes blue_leaf77
Ok. But for example, for third exiting state ## \Delta \hat{x} \Delta \hat{p}_x## is larger then in second exited state. What that means physically?
Actually, ##e^{-\alpha a^\dagger}## is not unitary.
The transformation of the ground state to the coherent state ##|\alpha \rangle## is unitary
$$|\alpha \rangle=\exp(\alpha \hat{a}^{\dagger}-\alpha^* \hat{a})|0 \rangle.$$
Note that
$$\exp(\alpha \hat{a}^{\dagger}-\alpha^* \hat{a})=\exp(-|\alpha|^2/2) \exp(\alpha \hat{a}^{\dagger}) \exp(\alpha^* \hat{a}).$$
Likes Demystifier
Sorry, my understanding is that a unitary operator, ##U##, is one for which, ##UU^\dagger = 1##. The above is clearly unitary, I stand corrected.
LagrangeEuler,
The ground state of a harmonic oscillator is not a coherent state, hence does not have coherence (definite phase). If you look at vanshees71's formula,
vanhees71 said:
|α⟩=exp(α^a†−α∗^a)|0⟩.|α⟩=exp⁡(αa^†−α∗a^)|0⟩,
and expand the exponential you'll get an infinite series in the creation operator acting on the ground state, creating an infinite series of number states (you also get an infinite series in the annihilation operator but this vanishes when operating on the ground state). The resulting state has no resemblance to the ground state.
Elemental
It's not just ##\vert \alpha\rangle## where ##\alpha=0##?
I think I have what may be a relevant input to this discussion. A very interesting and inconsistent result occurs if you use a photon model where each photon in the same mode has the same phase, and the E-fields from individual photons (may be incorrect to describe an E-field for a single photon) are all added in phase. The energy density U of the E-field , which is proportional to E^2 would then be proportional to N^2 where N is the number of photons. This dilemma is resolved if the phases of the individual photons are considered constant but random. The phasor diagram then becomes a 2-D random walk, with the result amplitude of the N photons proportional to sqrt (N). Thereby the energy of the E-field will be proportional to the photon number. Would anticipate this result has already been studied somewhere...
Likes gxu
Paul Colby said:
It's not just |α⟩|α⟩\vert \alpha\rangle where α=0α=0\alpha=0?
Paul Colby,
So it is! Tanking vanshee71's formula (which I'm sure is correct), the ground state is a degenerate case of a coherent state. I wouldn't draw too much from this though. I suspect phase coherence emerges as alpha gets larger, because the number uncertainty will grow with alpha. Glauber wrote several authoritative articles on coherent states in the 1960's (I believe); time permitting, I'll see if he addressed any of these questions there.
Elemental
Heh, first stop: grab a copy of Mandel & Wolf... :bow:
(And then maybe try Perelemov's book on generalized coherent states.)
(Of course the vacuum can be considered a coherent state, since the others a generated from the vacuum by the action of "displacement" operators similar to Hendrik Van Hees' formula. Such operators form a group and one can usefully define the concept of coherent states in terms of them.)
Likes Demystifier and vanhees71
Yeah, after checking Amazon, Mandel & Wolf looks like a must-buy; I hadn't read it since it was published after the time I was researching quantum optics.
Something I remember from the quantum mechanics course in graduate school is we entirely skipped over coherent states of the harmonic oscillator. We only studied stationary (number) states. Oscillators in stationary states don't move back and forth like the (macroscopic) oscillators I knew anything about, leaving me as confused as ever. So later I plowed through coherence theory on my own.
Interesting to note that that coherent states are sometimes referred to as "quasi-classical" states, because they most resemble the behavior of macroscopic oscillators found in nature. But, being eigenstates of the annihilation operator, they are non-orthogonal: a consequence of the annihilation operator being non-Hermitian. The ground (vacuum) state is also an eigenstate of the annihilation operator (generalized to the field operator in quantum field theory), since from the eigenvalue equation a|α⟩ = α|α⟩, but |α⟩ = |0⟩ when α = 0 (see above), in which case a|α⟩ = 0 = 0|α⟩. So undoubtedly the ground state is a coherent state.
Elemental
Likes vanhees71
Actually, if I might amplify Elemental's comments, coherent states also appear as a good description of thermal sources when suitably averaged. If I understand the calculation correctly, number states behave very differently than coherent states when subjected to a beam splitter. Consider a photon counting experiment with two detectors counting the two outputs of a beam splitter. For number states each photon detected either goes to port 1 and not port 2 or it goes to port 2 and not port 1. This is quite intuitive because macroscopic particles like machine gun bullets (and machine guns) behave this way in that there is an anti-correlation between bullet counts. For a machine gun our beam splitter could be a blade deflecting the bullet up or down. This anti-correlation for bullets is independent of the number of machine guns or their firing rate. For photons and the vast majority of photon sources the correlation is 0. For coherent states the statistics of the two outputs of the beamsplitter are completely uncorrelated.
Likes gxu and vanhees71
  • · Replies 16 ·
  • · Replies 67 ·
