Colliding particles, level 3 difficulty
8 replies · 8K views · last reply
mbrmbrg
Halliday 7e chapt 4 #16 (with web generated values)
In the figure (attatched), particle A moves along the line y = 33 m with a constant velocity of magnitude 3 m/s and parallel to the x axis. At the instant particle A passes the y axis, particle B leaves the origin with zero initial speed and constant acceleration of magnitude 0.47 m/s2. What angle θ between and the positive direction of the y-axis would result in a collision?
I got theta = 74 degrees, which is wrong. Here's my work:
PARTICLE A:
x_0=0m
y_0=y=33m
v_0=v=3 m/s
a=0m/s^2
PARTICLE B:
x_0=0m
y_0=0m
v_0=0m/s
a=0.47m/s^2
a_x=0.57sin theta
a_y=0.47cos theta
(NOTE: theta is not conventional. It is measured from the y-axis)
GENERAL:
collision occurs when A and B have the same x and y co-ordinates.
I did some simplifying of [itex]x=x_{0}+v_{0}t+\frac{1}{2}at^2[/itex] and arranging what I know and got the following 6 equations:
[itex]y_{A}=y_{B}[/itex]
[itex]x_{A}=x_{B}[/itex]
[itex]y_{A}=y_{0A}[/itex]
[itex]x_{A}=v_{0A}t[/itex]
[itex]y_{B}=\frac{a\cos\theta\t^2}{2}[/itex]
[itex]x_{B}=\frac{a\sin\theta\t^2}{2}[/itex]
and from these I get the following two eqations:
1) [itex]y_{0A}=\frac{a\cos\theta\t^2}{2}[/itex]
2) [itex]v_{0A}t={a\sin\theta\t^2}{2}[/itex]
solve equation 2 for t, and subsitute that value into equation 1 to get:
3) [itex]y_{0A}=\frac{a\cos\theta}{2}\(\frac{2v_{0A}}{a\sin\theta})^2[/itex]
distribute the squared and kill all fractions in equation 3 to get:
[itex]y_{A}a(\sin^2\theta)=2(v_{0A})^2\cos\theta[/itex]
Replacing sin^2(theta) with 1-cos^2(theta) and moving everything to one side gives a quadratic equation in the form ax^2+bx+c=0. Plug it into the quadratic equation to get:
[itex]\frac{-2(v_{0A})^2\pm\sqrt{4v_{0A}+(4)(y_{A}^2)(a^2)}}{2y_{A}}[/itex]
Sove in values from the table, and voila, either 144.699 degrees or74.296 degrees. Both of which are wrong. Help?
Actually, when taking the arctan of an angle, sometimes you have to subtract your answer from 180 degrees. Is this a similar situation? If so, what do you add/subtract when using arccos?
EDIT: I would think to subtract the angle from 360 degrees, but that would give me an angle poingting below the x-axis, and in this case, that would prevent the two particles from ever colliding. So it can't be that.
Anyone? Did I skip too many intermediate steps to warrant help?
Beats me; it's a WebAssign problem. I type in the answer and the computer says yes or no. It's not 74 degrees; I think I may have punched in fifty-something degrees at one point, also.
hmmm. cause i worked out the problem and got down to a tan(x)sec(x)=3.9 and had to use a graphing calculator to solve for x. it's been a while since i have done trig-ID's, so a implicit way to solve for x is escaping me...or i might hae just done the problem wrong.
shame... :sigh:. Well, the due date has passed to hand in the assignment, so I'll just get the answer in recitation... I wish I could figure this out, though!
well, here is how i worked it. maybe this will help.
(.47)sin(x)=a_y (acceleration in the y direction).
(.47)cos(x)=a_x (acceleration in the x direction).
(position of particle A)X_a=(3m/s)t
(position of particle B in the y direction)33=(1/2)(a_y)t^2
(position of particle b in the x direction)X_b=(1/2)(a_x)t^2
X_a=X_b
(3m/s)t=(1/2)(a_x)t^2
t=(6/a_x)
33=(1/2)(a_y)(6/a_x)^2
(a_y/(a_x)^2)=66/36
this resulted in tan(x)sec(x)=3.9
however, I'm thinking this might be wrong since the answer is explicit as of now.
But the angle we're looking for is with respect to the y-axis?
X_a=X_b
t=(6/a_x)
(a_y/(a_x)^2)=66/36
Woof. I am too tired to understand this now(12:41 my time), I'll look it over tomorrow. Thanks, though!
