Center of Mass Velocity in Elastic Collision
In an elastic collision involving two carts, one moving at 12 m/s and the other initially at rest, the center of mass (v_cm) needs to be calculated before the collision. The equations for momentum and kinetic energy conservation are applied to derive the velocities post-collision. The correct approach involves summing the momenta and dividing by the total mass to find v_cm. The discussion highlights the importance of considering direction when calculating velocities, especially in elastic collisions. Ultimately, the center of mass velocity is crucial for understanding the dynamics of the collision.
postfan
A cart of mass m moving at 12 m/s to the right collides elastically with a cart of mass 4.0 kg that is originally
at rest. After the collision, the cart of mass m moves to the left with a velocity of 6.0 m/s. Assuming an elastic
collision in one dimension only, what is the velocity of the center of mass (vcm) of the two carts before the collision?
(A) v_cm = 2.0 m/s
(B) v_cm = 3.0 m/s
(C) v_cm = 6.0 m/s
(D) v_cm = 9.0 m/s
(E) v_cm = 18 m/s
I just gave an arbitrary distance of 60 meters initially between the carts with the moving cart being at x=0 at t=0. During t=0 the center of mass is (60-0)/2=30 and at t=1 the center of mass is (60+12)/2=36, implying that C is correct however this is B, what am I doing wrong?
For the velocity of the center of mass, you need to sum the ##m_i \dot{\vec{r}}_i## and divide by M.
OK since the collision is elastic both momentum and kinetic energy is conserved so I came up with 2 equations :
1) m1v1=m1v2+m2v3
2).5m1v1^2=.5m1v2^2+.5m2v3^2
where v1=12, v2=6, and m2=4 with everything else being unknown.
I got m=15/8 ( didn't bother with v3 since before collision the second block is at rest).
I summed up all the momentums, took it over the masses and got 180/47 which doesn't correspond to any of the answer choices. What am I doing wrong?
##v_1## and ##v_2## are vectors going in opposite directions.
OK, making sure that my vectors were in the right direction so v2=-6 I got m1=4/3. using your equation (I assumed you meant velocity instead of radius), I got an answer of 3. Assuming that's right, one more question how do you derive that formula for center of mass velocity?
You take the center of mass position equation:
##x_{cm}=\frac{m_1x_1+m_2x_2+~...~+m_nx_n}{m_1+m_2+~...~+m_n}##
And replace position by velocity:
##v_{cm}=\frac{m_1v_1+m_2v_2+...+m_nv_n}{m_1+m_2+...+m_n}##
Basically just taking the time derivative.
Oh OK, was my answer right though?
the easy way to check:
velocity after, relative to com_velocity, is negative 1 times velocity before, relative to com_velocity ... (-1, for perfectly elastic; 0 for perfectly inelastic):
-6 (m/s) minus 3 (m/s) = -1 ( 12 minus 3 ) (m/s) ... -9 m/s = - 9 m/s
What?
Do you actually not recognize the values from your own problem?
Any velocity is always relative to some other velocity. relative means to subtract it ("minus" above)
The velocity of a cow, relative to an InterState trucker driving to California, is 70 mph Eastward.
Collisions are most simple if viewed from the center-of-mass; in that frame, total momentum is zero.
Before collision: the massive car approaches slower, from the other direction
After bouncing: both cars charge direction, and recoil away (outward); the massive car is slower.
  • · Replies 32 ·
  • · Replies 40 ·
  • · Replies 25 ·
  • · Replies 24 ·
