Combinations and Permutations in Briefcase and Coin Problems
The discussion focuses on calculating combinations for specific digit arrangements in a briefcase lock and coin selection problems. For the 5-digit combinations, the correct approach involves selecting two pairs of distinct digits and one additional distinct digit, leading to a formula of 10*9*8 multiplied by the arrangement factor of 5! divided by the factorial of the pairs. The second problem involves selecting a pair and three distinct digits, where the method of arrangement also plays a crucial role. In the coin selection scenario, the participant seeks clarification on how to account for conditions such as having a minimum number of certain coins. The conversation highlights the importance of understanding both selection and arrangement in combinatorial problems.
lee534
Hi all I need some assistance
1. Homework Statement with the attempt
How many 5-digit briefcase combinations contain
1. Two pairs of distinct digits and 1 other distinct digit. (e.g 12215)
I wasn't sure on which approach was correct.
10 * 9 * 8 (because there are three distinct digits)
or
10C2 * 5C2* 3C2 * 8 (because you have to take into account how the doubles can be orientated)
2. A pair and three other distinct digits. (e.g 27421)
same issue as above
10*9*8*7
or
(5C2*10) * 9 * 8 * 7
lastly
I have found this question before but I couldn't get an explanation:
How many ways are there to pick a collection of 12 coins from piles of pennies, nickels, dimes, quarters, and half-dollars? Base on the following condition:
1. there are only 10 coins in each pile.
16C4 - 5^2 because it's the total minus how many ways I can get from the 11th coin and the 12th coin. = 1795
2. There are only 10 coins in each pile and the pick must have at least one penny and two nickels?
1795 - 13C4(?)
my logic is that it's because 12-3+4 C 4 but I'm not sure if I have to set it to 12 or 10.
Thank you!
I only have a minute, but I'll see what I can get through:
1. First let's pick which digits are going to be used. There are 10 choices for the first paired digits, 9 choices for the second paired digits, and 8 choices for the lone digit. So there are ##10*9*8## ways to choose these digits. Now we have to order them. If we could distinguish our five numbers, the number of ways to order them would be ##5!##. But we have those two indistinguishable pairs. So, for example, putting our first pair in the second and fourth position, we be counting this twice in the ##5!##. So we need to divide by two for each of the pairs. Thus the number of ways to order our 5 numbers accounting for the fact that there are two pairs is: ##\frac{5!}{2*2}##.
Thus the total number of combinations is: ##10*9*8*\frac{5!}{2*2}##.
for the positioning
would it matter if the doubles were not next to each other for ex.
12125 or 13212?
That's not quite right. E.g. 11223 gets counted both by picking two 1s, then two 2s and by picking them in the other order.
AH I solved it!, Thank you for replying to the posts!
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
13K
  • · Replies 100 ·
12K
  • · Replies 67 ·
11K
  • · Replies 64 ·
16K
  • · Replies 55 ·
11K
10K
