How Many Paths Exist from (0, 0, 0) to (a, b, c) in a 3D Grid?
  • Thread starter Thread starter dancergirlie
    Combinatorics Path
The discussion focuses on calculating the number of paths from the origin (0, 0, 0) to a point (a, b, c) in a 3D grid, where movement is restricted to increasing one coordinate at a time. The solution employs combinatorial mathematics, specifically the binomial coefficient, to derive the total number of paths as \(\binom{a+b+c}{a} \cdot \binom{b+c}{b}\). This approach effectively extends the 2D pathfinding method to three dimensions using multinomial principles.
  • Understanding of combinatorial mathematics and binomial coefficients
  • Familiarity with the concept of paths in a grid
  • Knowledge of multinomial formulas
  • Basic proficiency in mathematical notation and sequences
  • Study the properties of binomial coefficients and their applications in combinatorics
  • Explore the multinomial theorem and its relevance to path counting in higher dimensions
  • Learn about dynamic programming techniques for pathfinding in grids
  • Investigate related problems in combinatorial optimization
Mathematicians, computer scientists, students studying combinatorics, and anyone interested in algorithm design for pathfinding problems.
dancergirlie
Let a, b, and c be positive integers. How many paths are there from (0, 0, 0) to
(a, b, c) if we are only allowed to increase one of the coordinates by one at each
step?
This problem is easy for the path between (0,0) to (a,b)
because you can make the path into a binomial sequence, where if you increase a, then that will be a one, and if you increase b, then it will be a zero.
so for two:
total number of digits in the binary sequence= a+b
where a= # of 1s and b=#of 0's
So the total # of paths=
(a+b) choose a, which is equivalent to (a+b) choose b.
However for (0,0) to (a,b,c)
the total digits in the binary= a+b+c
and define the number of ones as a
and non-ones (zeros)= a+b
which yields:
Total path #s= (a+b+c) choose a.
I think the answer is:
((a+b+c) choose a)((b+c) choose b)
However, how do I explain that? Can i define c as the number of two's in the binary sequence? I thought binaries only had ones and zeros, that is why I haven't done that. Any help would be great!
This can be done using a multinomial formula.
But yes
\left( \begin{array}{c}{a+b+c}&{a}\end{array} \right) \left( \begin{array}{c}{b+c}&{b}\end{array} \right)
is fine.
--Elucidus
  • · Replies 18 ·
