Can I Create a Visible Light Pattern Using a Combination of Laser Beam and LED?
The discussion focuses on creating a visible light pattern using a combination of a laser beam and an LED. The user aims to achieve a bright dot in the center, reminiscent of a sniper sight, along with a filled circular pattern around it, specifically 8 inches in diameter at a distance of 4 feet. The user suggests that red light is optimal for visibility in bright conditions and seeks advice on combining the laser and LED effectively, considering options like a two-way mirror or a lens with a hole. The project is intended as a fun hack for a toy laser 'shotgun'.
  • Understanding of basic optics principles
  • Familiarity with laser and LED technology
  • Knowledge of light dispersion techniques
  • Experience with DIY electronics projects
  • Research methods for combining laser beams with LEDs using optics
  • Explore the use of two-way mirrors in light pattern creation
  • Investigate lens designs that can create specific light patterns
  • Learn about the properties of red LEDs for visibility in bright environments
This discussion is beneficial for hobbyists, DIY electronics enthusiasts, and anyone interested in optics and light pattern creation for projects or experiments.
DannySmythe
I want to create a visible pattern of light from 1-5 feet away. The pattern would have a bright dot in the middle (ala sniper sight) visible in bright light at 5 feet. The cheap toy pointers seem to work just fine. It would also have a filled circular pattern around the dot, 8" in diameter at 4' and visible at about 3' in bright light. I have an LED that does this fairly well with the right diversion (dispersion?) angle. Red seems to be the best color.
So I have 2 questions
1. How do I combine the laser beam with the LED? All of the optics needs to be packaged in a narrow tube about 1/2' in diameter. I know that a prism of some kind might work but I don't want to spend a lot of time machining down a large prism. What about a mirror with a 2-way coating?
2. Even better, is there a way to produce this pattern with just the laser. Maybe a lens with a hole?
This is just a hack for a toy laser 'shotgun' just for fun.
So all ideas and criticisms cheerfully accepted.
Science news on Phys.org
I think you'll get better answers on a hobbyist forum than on a physícs forum.
That's kind of offensive anorlunda.
So just because this is a fun hack for a toy, it's beneath the mean of this forum?
Do others feel this way?
Why would I go to a hobbyist forum for answers about optics?
I've had some great responses here about water flow for my rainbarrels and water conservation projects. I guess I should have gone to a plumbers forum to ask about fluid dynamics.
I guess I should have said "So most ideas and criticisms cheerfully accepted."
  • · Replies 40 ·
  • · Replies 25 ·
