Combined Gas Law: 3L Air Increase in 300K Tank
  • Thread starter Thread starter OmCheeto
    Gas Gas law Law
The discussion revolves around the Combined Gas Law (CGL) and its application to a scenario involving the pumping of air into a cylinder, specifically addressing the resulting temperature changes and the underlying physics of the process. Participants explore concepts related to adiabatic processes, energy transfer, and real-world implications of theoretical models.
  • One participant expresses confusion about the CGL and the expected temperature rise when pumping air into a filled cylinder at an initial temperature of 300K, questioning if the rise is solely due to friction in the pump.
  • Another participant suggests that the temperature increase is due to the addition of energy from gas compression, indicating that various models may apply depending on assumptions made.
  • A participant references the adiabatic process, noting that while it typically implies no heat transfer, there can still be internal temperature rises during rapid compression.
  • Concerns are raised about the idealized nature of adiabatic processes as described in textbooks, with a participant seeking a more practical understanding of temperature versus pressure relationships.
  • There is a discussion about the need for clarity regarding the pumping process and its impact on temperature changes, with some participants suggesting that the physics of the pump and tank may not need to be treated as separate problems.
  • One participant mentions the complexity of understanding changes in state as presented in their textbook, indicating a struggle to formulate the correct questions regarding the phenomena being discussed.
  • References to external sources, including archived forum discussions and Wikipedia articles, are made to seek further clarification on the concepts involved.
Participants do not reach a consensus on the nature of the temperature rise or the application of the CGL in this context. Multiple competing views and uncertainties remain regarding the underlying physics and practical implications of the discussed processes.
Participants highlight limitations in their understanding of the assumptions underlying the CGL and adiabatic processes, as well as the challenges in applying theoretical models to real-world scenarios. There is an acknowledgment of the complexity involved in determining the relationships between temperature, pressure, and volume in practical applications.
OmCheeto
I'm a bit confused about the cgl.
If I pump 3 liters of air into a 3 liter cylinder already filled with 3 liters of air, what will be the temperature rise? Assuming an initial temperature of 300'K. It seems like from practice, the temperature goes up. Is the temperature rise due strictly to the friction in the pump?
Should I break this down into two separate problems? the physics of the pump and that of the tank?
You'll sort of have to describe your pumping process a little bit more.
hmmm... those german rotary compressors seem a bit spendy, so I was thinking in the line of the piston pumpers you can buy for $14.99 at shucks.
I looked in my physics book and they described the adiabatic process where there is no temperature rise, but that seemed a bit too perfect.
I guess I'm looking for a real world temperature vs pressure curve.
What are you confused about exactly? The CGL is pretty straight forward.
Yes the temperature goes up.
No, the temperature increase is due to the addition of energy as a result of the compression of the gas. Since the gas is being added by a pump, you can think of it as a piston compressing a given quantity of gas. So as the piston compresses the gas in the reservoir (tank), negative work is done and the internal energy of the gas is increased.
Be aware that there are various ways to model the change from the intial state to final state of the gas depending on the assumptions made.
Not really, it's probably not necessary. I don't think the seals of the piston would add that much heat from friction.
In an adiabatic process, there can be a temperature rise internally. An adiabatic process is one in which there is no transfer of energy as heat between the system and the enviornment (i.e. one in which the expansion or compression is very rapid, or the system is well insulated).
I guess that's why I asked for a real world answer, and why TVP45 asked for the pumping process. I will go back to my text and try and figure out where a temperature rise can occur in the perfect system.
I just explained where the temperature rise comes from in post #4. Was that not clear enough? If not we can try again.
Your physics book should have some good examples also. If not, a google search should pull up some more info.
I'm starting to feel like Will Smiths character in I Robot.
I seem to not know what the correct question is.
I re-read the section on adiabatic processes and see that you are correct.
I think my confusion comes from reading my book. They speak either of constant temperature or of constant pressure, or in the real world scenario they give initial and final states of the system where both change, but not why they changed as they did.
Googling actually brought me to this forums archives where Pengwuino was asking basically the same thing: https://www.physicsforums.com/archive/index.php/t-81104.html
(though I'm not interested in creating liquid nitrogen)
There I found the requirement of a second equation: PV^(gamma)=k
where gamma = 7/5 in my case
They reference: http://en.wikipedia.org/wiki/Adiabatic_process
and http://en.wikipedia.org/wiki/Ideal_gas_law
where we get pV=nRT
The combined gas law doesn't really tell me much as indicated by this calculator: http://www.1728.com/combined.htm
It just tells you that you have to know the value of 5 variables to get the 6th.
Which is totally useless. I can even use it to prove you wrong: Cut the volume in half and double the pressure and there is no temperature change.
Sooner or later I will determine what my question should be.
Anyways, I'm late for work. I'll work on the solution later.
  • · Replies 45 ·
10K
  • · Replies 23 ·
  • · Replies 20 ·
