Combined resistance in this circuit
  • Thread starter Thread starter Eitan Levy
    Circuit Resistance
12 replies · 2K views
Eitan Levy
What is the combined resistance when the switch is closed?
IR=V
I found that I1=5.2A and that I2=9.1A. The answers follow suit.
Now I thought that calculating the combined resistance with 60/(I1+I2) would be correct, however the answer is 4Ω.
Can anybody help me out in this? Thanks.
on Phys.org
IR=V
Show your work. Show how you combine various resistors to get the total resistance
I didn't think I should do this. Why is it wrong to just divide the voltage by the total current? This gives 4.2 instead of 4. We didn't study how to really combine the resistors when they are connected like this.
You have computed something with the switch open and you are applying it when the switch is closed. That just flat does not work. You HAVE to figure out the combined resistance with the switch closed.
What do you mean? These currents are for when the switch is CLOSED, not open.
They how could you possibly have gotten it without combining the resistors?
Eitan Levy said:
...however the answer is 4Ω.
How do you know that the answer is 4Ω ? Was this a multiple choice question? Or perhaps they want the result rounded to an appropriate number of significant digits?
I thought it doesn't matter how I reached those currents. I did combine the resistors in order to reach those current, and they are correct.
Maybe they did but it would be very unusual. This is the answer written in the answers as correct.
Eitan Levy said:
I did combine the resistors ...
So you don't think you should combine the resistors but you did combine the resistors?
Using a delta-wye transform I get an equivalent resistance that is compatible with the sum of the currents you stated, and of course, it's not 4 ohms. Since you combined the resistances, you MUST have gotten the same thing I did, else you could not have gotten the right total current.
This method is correct provided that your current values are correct. If, for correct current values, your result doesn't match the supplied answer for the total resistance with the appropriate number of significant figures for the given data, then that supplied "correct" value is not accurate.
Alright, thanks for the help!
