How Do Decibel Levels Combine in Different Scenarios?
  • Thread starter Thread starter nokia8650
    Levels
The discussion centers on calculating combined decibel levels and understanding sound pressure differences. When adding two identical tones of 88 dB SPL, the total sound pressure level is correctly calculated as 94 dB SPL using the formula dB SPL = 20log(P/2*10^-5). For the relationship between A, B, and C, A is determined to be 60 dB above C, as A is 100 times louder than B and B is 10,000 times louder than C. Additionally, to find the decibel difference when the sound pressure of D is four times that of E, the calculation involves using 20log4. The conversation emphasizes the importance of understanding logarithmic relationships in sound pressure levels.
nokia8650
1. What is the total sound pressure levels of two identical tones, each 88db SPL, when added together?
For this question, using the equation dB SPL = 20log(P/2*10^-5), I found the value of P where dB SPL = 88, then doubled this value, then fed it back into the equation, to obtain a value of 94 db SPL. Is this correct?
2. If A is 20dB above B and B is 40dB above C, how many decibels is A above C?
I was struggling with this question - does anyone have any advice on how to tackle it?
Yes. A less tedious way to do it would be to realize that log(2x)=log(x)+log(2), so dB SPL increases by 20*log(2).
Why would it not be 60? If you need to convince yourself, 20dB corresponds to a factor of 100, 40dB to a factor of 10,000. A is 100 times louder than B and B is 10,000 times louder than C, so A should be 10^6 times louder than C. That's 60 dB.
Ahh yes I see, thank you! However, does 20dB not correspond to a factor of 10, and 40dB to a factor of 100, given the fact it is dB SPL, and hence 20logx as opposed to 10logx?
Also, the next part of the question asks - if the sound pressure of D is four times that of E, by how many decibels do they differ? For this, would one simply find 20log4?
Thanks again
Oops. You're completely right--it should be a factor of 10, not 20. Sorry about that.
Yes.
10K
