Combustion EQ of liquid Hydrogen and liquid Oxygen
The balanced combustion equation for liquid hydrogen (LH2) and liquid oxygen (LOx) in a Space Shuttle Main Engine (SSME) is 2H2 + O2 > 2H2O + H2, accounting for an air-fuel (AF) ratio of 6. The reaction does not reach complete stoichiometry due to high flame temperatures causing thermal decomposition of water. Additionally, the presence of excess hydrogen as a byproduct complicates the reaction dynamics, necessitating careful consideration of mass balance rather than solely focusing on the balanced equation.
  • Understanding of combustion chemistry
  • Familiarity with stoichiometric calculations
  • Knowledge of air-fuel ratios in combustion processes
  • Basic principles of thermal decomposition
  • Research the effects of high flame temperatures on combustion reactions
  • Study the role of excess hydrogen in combustion processes
  • Learn about mass balance calculations in chemical reactions
  • Explore combustion dynamics in rocket propulsion systems
Aerospace engineers, combustion scientists, and students studying rocket propulsion and chemical reactions in high-temperature environments will benefit from this discussion.
MechStudent123
Im working on a problem regarding a SSME and need to figure out the balanced eq for LH2 and LOx.
I thought it was simply.. H2 +0.5O2 > H2O however my professor has confirmed that it is not the case in this situation. I am stumped as to what it could possibly be, maybe excess H2? And am not supposed to include dissociation for the reaction.
Chemistry news on Phys.org
No idea what else it could be, this is the correct overall reaction equation. The mixture is definitely not exactly stoichiometric during the reaction, and the flame temperature is so high some of the water produced undergoes thermal decomposition (or, more precisely, the mixture never reacts to the end till it cools down a bit outside of the engine and the output flame), but in the end it is just a water synthesis.
Do you have contamination of the reaction by air?
BoB
BoB
I ended up figuring it out
2H2 + O2 >2 H2O + H2 then baa fed for the AF of 6
I believe this was the eq I ended up using, not looking at it right now. *balanced
Huh?
Then balanced the equation. I guess the ssme produces h2 as a byproduct
If you balance
H2 + O2 → H2O + H2
you will find no hydrogen on the right (coefficient of zero) and you will end with exactly the same equation you listed in your very first post.
I have researched a few articles about the combustion in a ssme. There is excess 'energy' in the form of monotomic or diatomic hydrogen. Will link the reference soon.
If you know there is a AF ratio of 6 on a mass basis then you will get the complete eq
Balancing the eq you stated above could result in an infinite number of solutions without the AF ratio..then again I could be wrong, haven't received my grade back
Perhaps that's a bit of nitpicking on my side, but when you include excess reagents (together with the inert compounds) you get a mass balance for the process, not the balanced reaction equation. In some ways they are similar, in other ways they are distinct.
9K
