Common Time: Explaining Einstein's Definition
The discussion revolves around Einstein's definition of "common time" as presented in his paper on relativity. Participants explore the implications of synchronizing clocks in different locations and the conceptual understanding of time measurement in the context of relativity theory.
  • Some participants question what is meant by "common time" and whether it implies that two clocks display the same value simultaneously.
  • Others propose that "common time" refers to a time standard that can be shared between events occurring at different locations, suggesting a synchronization convention for comparing times from different clocks.
  • A participant introduces a mathematical approach to determine the time light takes to travel between two points, suggesting that the midpoint could represent a common time.
  • There are concerns about the clarity of Einstein's definitions, with some participants expressing confusion about why he does not simply state that the clocks should display the same value at all times.
  • Questions arise regarding the definition of "at the same moment" and whether different procedures could yield varying results in clock synchronization.
  • One participant mentions a practical synchronization method involving Time Synchronize Officers adjusting clocks to a standard, contrasting it with Einstein's light-based synchronization method.
Participants express various interpretations of Einstein's concept of common time, leading to multiple competing views on the synchronization of clocks and the definition of simultaneity. The discussion remains unresolved regarding the clarity and implications of these concepts.
Participants highlight the complexity of synchronizing clocks and the potential for different interpretations of simultaneity, which may depend on the procedures used for synchronization. The discussion reflects a range of understandings and assumptions about the nature of time in relativity.
WilliamMGiraldo
Hi.
Thanks for letting me ask this question. It is a stupid one.
I'm a newbie at relativity theory, and I'm reading On the electrodynamics of moving bodies, By Einstein, A. He associates time with space, and tells us that you can measure the "time" of an event if you are in the coordinates of the event with a wristwatch.
However, he says that:
¿Why does this defines a common time? ¿What is common time? ¿Is it that the two clocks display the same value?
This is the document in question: http://hermes.ffn.ub.es/luisnavarro/nuevo_maletin/Einstein_1905_relativity.pdf
In context, this "common time" would be a definition of time that is common to (that is a time standard that is shared between and can be used for) both events near A and events near B. He is leading toward what we would describe as "coordinate time" and is suggesting a synchronization convention that can be used to allow times measured by clock A over here to be validly compared with times measured by clock B over there.
In this context "common" means "shared" or "agreed on". We can all agree that everything that happens in the vicinity of B when clearly clock B's hands point to noon happens at the same time, noon according to clock B; and likewise for clock A. But if we want to compare the times of events happening in the vicinity of A and events happening in the vicinity of B we need something more: we need to know whether clock A read noon at the same time as clock B. Einstein is describing exactly what it means to say that they do.
Hello
By transposition
[tex]t_B=\frac{t_A+t'_A}{2}[/tex]
Light starts A at 1:00
Light reflects back to A at 3:00
The time when light reaches B should be 2:00, the middle.
It seems reasonable to me.
On a side note, I strongly suggest against trying to learn relativity from the original papers. You will be missing more than 100 years' worth in didactical and pedagogical development with respect to relativity. Once you have learned the theory from modern sources, it will be of historical curiosity to go back and see how the original papers were written.
Likes   Reactions: ComplexVar89, WilliamMGiraldo, jbriggs444 and 1 other person
Hi. Thanks to everybody for replying, I'm very excited to learn this topic.
You are right, but I'm not only studying the theory; I'm also studying the man.
sweet springs said:
Hello
By transposition
Exactly! But, then, why not just say that at every moment, both clocks display the same value? That would satisfy [tex]t_B-t_A=t'_A-t_B[/tex] and would be a lot less confussing. So I feel I'm not understanding the ideas beneath.
Yeah, that's what he says. But then; is he just saying that the clocks must display the same value? Because he could have said just that [tex]t_B=t_A+\Delta t[/tex] where [tex]\Delta t[/tex] is the time it takes for the light to reach B from A.
tB−tA=t′A−tB​
What does it mean for two clocks to display the same value at the same moment? That is, what does "at the same moment" mean? How do you define it in terms of an experiment that can be performed?
Is there more than one procedure that could be used that would give different results? [hint: the answer is yes].
Let the A and B clocks be together; they resemble in all aspects each other, so you can tell that the hands of these two clocks are always at the same position with respect to each other. That is, if you put them in a bag, shake it, and randomly get any of them out of the bag, you can't tell if the one you chose is the one who belongs to A or B.
That said, and ignoring the relativistic effects of walking, you walk and put one of these clocks at A and the other at B. ¿Is this what Einstein is trying to say? ¿Why to involve light in the subject?
Hi.
Time Synchronize Officers who adjust their watches to a standard clock at the Central Office, travel around the country and adjust the clocks everywhere to his/her watch. Such a synchronization system works. Correct but boring as you say. The light procedures seem to be redundant.
However, when you proceed to section 3 of the paper, you will find it exciting to compare two synchronized systems that are moving each other and the relation [tex]t_B-t_A=t'_A-t_B[/tex] is quite beneficial to do that. Be patient.
  • · Replies 43 ·
  • · Replies 62 ·
16K
  • · Replies 17 ·
  • · Replies 51 ·
