Commutation relations for Spin opertors
The discussion centers on the commutation relations of spin operators, specifically addressing the confusion surrounding the commutation of polarizers aligned at 0 and 90 degrees. The experiment designed by Serkan demonstrates that using two perpendicular polarizers results in no light transmission, leading to the erroneous conclusion that the operators Sx and Sy commute, represented by [Sx, Sy] = 0. However, the correct relation is [Sx, Sy] = ihSz, indicating a fundamental misunderstanding of the relationship between spin operators and the polarization of light.
  • Understanding of quantum mechanics, specifically spin operators
  • Familiarity with polarization of light and its measurement
  • Knowledge of commutation relations in quantum mechanics
  • Basic principles of linear and circular polarization
  • Study the mathematical framework of quantum mechanics, focusing on spin operators and their commutation relations
  • Explore the principles of light polarization, including linear and circular polarization
  • Learn about the measurement process in quantum mechanics and how it relates to operator algebra
  • Investigate the implications of the uncertainty principle in the context of spin measurements
Physicists, undergraduate students in quantum mechanics, and educators designing experiments related to spin and polarization will benefit from this discussion.
sakkoyun
Dear physicist,
I designed an experiment for my undergraduate students. As we know, for spin operators, the commutation relation is
[Si,Sj]=ihSk
We also know, if we use two polarizers which are perpendicular each other, there is no light other side after polarizers. Namely apparatus is like,
Light source ------> 0 degree polarizer + 90 degree polarizer ------->Luxmeter (no light)
If we commute these two as,
Light source ------> 90 degree polarizer + 0 degree polarizer ------->Luxmeter (no light)
So we can say, 0 and 90 degree polarizers can commute. 0 degree polarizer may be named Sx operator and 90 degree polarizer may be named Sy operator.
According to the result of this experiment,
[Sx,Sy]=0.
Whereas [Sx,Sy]=ihSz is the rule.
Where is the problem in my mind?
Best wishes.
Serkan
Serkan, You can't identify the E-field components Ex and Ey with spin components Sx and Sy. Light is made of photons, whose spin component is always parallel or antiparallel to the propagation vector. These correspond to left- and right-handed circularly polarized waves. Linearly polarized waves are linear superpositions of the circular polarizations.
Is Serkan identifying the spin and E-field components? I don't think so.
I think the important point is that, as you said, the polarization vector for light is orthogonal to the direction of propagation. If x and y are taken in the plane perpendicular to the light beam, then the z-axis points along the beam, so we have that Sz is zero, and hence there's no contradiction. (Serkan, note also the difference between mutliplying operators together, which makes no reference to states, and actually performing measurements of a real physical system!)
Thank you very much for your interest. According to the results from you:
1. SxSy-SySx=0. This equation don't tell us that these operators can be commuted each other. Actually, we can not measure the polarization of the light in the z direction via the apparatus given in the first post.
2.SxSy or SySx multiplyings give pure imagine result, so we can not measure them. So we obtain SxSy=0 and SySx=0. Hence, SxSy-SySx=0-0=0.
good works,
Serkan
As I thought, Serkan, you are still confused. A polarizer measures and filters the alignment of the E field. If you pass a beam of light through a polarizer aligned in the x direction, the only light that gets through will have its E field pointed in the x direction. You are confusing this with spin. The polarizer does not in any sense measure Sx.
  • · Replies 71 ·
  • · Replies 58 ·
  • · Replies 74 ·
  • · Replies 87 ·
