Commutator with r, p_r and angular momentum
3 replies · 7K views · last reply
omyojj
Hi, guys..This is my first time to post. and I got to aplogize for my bad English..I`m a novice..;;
anyway..here`s my curiosity..
From Paul Dirac`s Principles of Quantum Mechanics..p.153
(section of Motion in a central field of force)
It says that
The angular momentum L of the ptl about the orgin ..and its magnitude L^2 commute with r and p_r since they are scalars...
It`s not hard to verify that [L, r] = [L, p_r] = 0
(L_x=x*p_y-y*p_x, r=(x^2+y^2+z^2)^(1/2) etc.)
But I just want to understand the underlying physics..
commutator(Quantum Poisson`s Bracket) with L zero?
Are they concerned with conservation of angular momentum? or else?
L^2 is a Casimir operator for the Lie algebra of angular momentum. It just means that r and p_r are \phi independent, and \phi is the canonically conjugate variable of angular momentum.
I don`t have any idea what Casimir operator is..
But canonically conjugate variable of angular momentum phi is surely indep. of p_r, r
thx a lot!
Operators of angular momentum [itex](L_x, L_y, L_z)[/itex] play the role of generators of rotations (actually, this property can be used as a definition of [itex]\mathbf{L}[/itex]). This means that if [itex]r[/itex] is distance measured in the reference frame O, then
[tex]r' = \exp(\frac{i}{\hbar} L_x \phi )r \exp(-\frac{i}{\hbar} L_x \phi )[/tex]...(1)
is the distance in the reference frame O' that is rotated with respect to O by the angle [itex]\phi[/itex] around the x-axis. Since [itex]r[/itex] is a scalar, it is invariant with respect to rotations ([itex]r'=r[/itex]). Then, by Taylor expanding exponents in the right hand side of (1) one can show that this invariance is equivalent to the vanishing commutator
[tex][L_x, r] = 0 [/itex]<br /> <br /> Commutators are closely related to inertial transformations in other examples as well. For example, the Hamiltonian is the generator of time translations, i.e., for any operator [itex]F[/itex] its time dependence is given by<br /> <br /> [tex]F(t) = \exp(-\frac{i}{\hbar} Ht )F\exp(\frac{i}{\hbar} Ht )[/tex]<br /> <br /> and [itex]F[/itex] does not depend on time if and only if [itex]F[/itex] commutes with the Hamiltonian. <br /> <br /> Eugene.[/tex]
