Compact Hausdorff Spaces: Star-Isomorphic Unital C*-Algebras
HeinzBor
ismorphism between hausdorff compact spaces on C(X) to C(Y)
Standard Algebra definitions.
If ##X## and ##Y## are homeomorphic compact Hausdorff spaces, then ##C(X)## and ##C(Y)## are ##star##-isomorphic unital ##C^{*}##-algebras.
So I got the following map to work with
(AND RECALL THAT ##C(X)## and ##C(Y)## are vector spaces).
$$C(h) : C(Y) \rightarrow C(X) \ : \ f \mapsto f \circ h$$
and thus to show linearity (one of the many statements) I must show that
$$((f+ \lambda g) \circ h)(x) = (f \circ h + \lambda g \circ h) (x) \ \ \lambda \in \mathbb{C}, g \in C(Y)$$
However, I am a bit confused on how to work with this mapping, any help is appreciated..
Isn't this simply the definition of the vector space property of ##C(Y)##?
Yea I assume I can work with the axioms of a vector space since the functions belong to C(X) and C(Y). However, I haven't had an algebra course for so long, so I am a bit confused on how to work with those definitions, when I have the composition instead of the usual product showing up. Am I allowed to just work with the composition as a standard product in a vector space?
You simply have ##h(x)=:y\in Y##. So if you write down the linearity in ##C(Y),## namely the linearity
(f+\lambda \cdot g)(y) := f(y)+ \lambda \cdot g(y),
in a function space, then you get exactly what you need. Only substitute ##y## by ##h(x).##
Ahhh yes ! of course.. $$X \rightarrow V$$ can be given the structure of a vector space over $$\mathbb{F}$$, if for any $$f,g : X \rightarrow V$$, $$x \in X$$, $$\lambda \in \mathbb{F}$$ $$(f+g)(x) = f(x) + g(x)$$ and $$(\lambda f)(x) = \lambda f(x)$$ and composition is associative..
Okay so for linearity:
((f + \lambda g) \circ h)(x) = f((h(x)) + \lambda g (h(x)))
= (f \circ h + \lambda g \circ h)(x)
Multiplicativity:
(f \circ g) ( g \circ h) (x) = f(g \circ h)(x)
= ((fg) \circ h) (x).
To show the mapping preserves involution:
(\overline{f} \circ h)(x) = \overline{f}(x)
= (\overline{f \circ h})(x)
$$Lastly I must show that it is unital i.e.
$$1 h = 1$$, somehow it seems really obvious, but how can h just be gone... $$h$$ was assumed to be a homeomorphism between to compact hausdorff spaces so its 1-1 and has continuous inverse...
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
