Comparing Euler methods for a stiff system of ODEs
  • Topic:
  • Thread starter Thread starter evinda
    Compare
38 replies · 12K views
I tried:
Code:
t2=[1 2];
y2=[3 4; 5 6];
plot(t2, y2(1,:).^2+y2(2,:).^2, 'y');
That works... (Thinking)
Did you perhaps put those functions in script files?
Or are you running the code on the prompt?
Btw, your current functions are not syntactically correct since 'for' has an 'end', but 'function' does not have an 'end'. (Worried)
Klaas van Aarsen said:
I tried:
Code:
t2=[1 2];
y2=[3 4; 5 6];
I wrote that code in a script .m and when I run it it is asked to enter a value for N. I give for example 100 and then I get the error message.
I did that in https://octave-online.net/
So, when you run that code it is executed normally without any error? (Thinking)
If I copy and paste your code in octave-online, I don't get any response. (Worried)
I expected that since those functions are not terminated with the [M]end[/M] that should come after. (Nerd)
What did you put in octave-online exactly?
How did you get the error? (Wondering)
There are two functions that I want to plot. Here you can see the functions I wrote then I press RUN and enter 100 as the value for N and as you can see I get again an error message. What have I done wrong? (Thinking)
If we put a function into a file named [M]ex.m[/M], then that file must contain exactly a function named [M]ex[/M] and no other statements.
Since that is not the case, we get an error that is unfortunately not very descriptive. (Worried)If we copy and paste your code into the regular command prompt of Octave online, we get:
Now we get the error that the variables are not known as I explained. (Nerd)Alternatively, we can create a new file named [M]trapezoid_method.m[/M].
Put the code of the function in there, and only that function.
Click the save button.
Type [M]trapezoid_method(10)[/M] on the command prompt.
Now it will execute the function as desired. (Happy)
And what if we write these two function into one?
I mean like that:
Code:
function [ ] = ex(N)
h=1/N;
A=[-5 -2;-2 -100];
%trapezoid_method
y=[1;1];
t2=[0];
y2=[y];
for (i=1:N)
      y=(eye(2)+h*A+h^2/2*A^2)*y;
      t2=[t2, i*h];
      y2=[y2, y];
end
%euler_method
y=[1;1];
t3=[0];
y3=[y];
for (i=1:N)
    y=inv(eye(2)-h*A)*y;
    t3=[t3, i*h];
    y3=[y3, y];
end
plot(t2, y2(1,:).^2+y2(2,:).^2, 'y', t3, y3(1,:).^2+y3(2,:).^2, 'b');
end
So that the variables are known, does the function have to return these? Or how can we fix the error that we get, that the variable are not known? I splitted the two functions into two files, the following:
Code:
function [ ] = euler(N)
h=1/N;
A=[-5 -2;-2 -100];
%trapezoid_method
%euler_method
y=[1;1];
t3=[0];
y3=[y];
for (i=1:N)
    t3=[t3, i*h];
    y3=[y3, y];
end
end
Code:
function [ ] = trapezoid(N)
h=1/N;
A=[-5 -2;-2 -100];
%trapezoid_method
y=[1;1];
t2=[0];
y2=[y];
for (i=1:N)
      t2=[t2, i*h];
      y2=[y2, y];
end
end
Then in the command line I wrote the following commands:
octave:1> trapezoid(100)
octave:2> euler(100)
octave:3> plot(t2, y2(1,: ).^2+y2(2,: ).^2, 'y', t3, y3(1,: ).^2+y3(2,: ).^2, 'b');
but I get again "error: 't2' undefined near line 1 column 6". What am I doing wrong? (Thinking)
Here's how it looks like at me:View attachment 9069
I mean like that:
That should work yes.
Does it? (Thinking)
Now we do not get the error that there is something wrong with the script any more. Good! (Happy)
The variables still need to be returned though.
We can do that with:
[M] function [t3, y3] = euler(N)
...[/M]
and:
[M]function [t2, y2] = trapezoid(N)
...[/M]
and:
[M]octave:1> [t2, y2] = trapezoid(100)
octave:2> [t3, y3] = euler(100)
octave:3> plot(t2, y2(1,: ).^2+y2(2,: ).^2, 'y', t3, y3(1,: ).^2+y3(2,: ).^2, 'b'); [/M]
(Emo)
...[/M]
and:
...[/M]
and:
(Emo)
I tried it like that. The command "[t2, y2] = trapezoid(100)" works. But the command "[t3, y3] = euler(100)" seems not to work, I get the following:View attachment 9070(Thinking)
It seems to work for me:
(Wasntme)
