Comparing Flat vs Banked Road Maneuverability
  • Context: Undergrad
  • Thread starter Thread starter mutineer123
    Flat
This discussion focuses on the comparison of maneuverability between flat and banked roads during circular motion. It establishes that on a flat road, the frictional force acts as the centripetal force, while on a banked road, the horizontal component of the normal force provides this centripetal force. The analysis reveals that maintaining the same speed on a banked road requires more force than on a flat surface due to the different forces at play. The conversation also emphasizes the importance of understanding the components of gravitational force and normal force in relation to the incline of the banked road.
  • Understanding of centripetal force and its calculation using the formula F = mv²/r
  • Knowledge of forces acting on an object on an incline, including gravitational and normal forces
  • Familiarity with free body diagrams to visualize forces
  • Basic principles of physics related to motion and acceleration
  • Study the effects of different bank angles on vehicle maneuverability
  • Explore the role of friction in circular motion on both flat and banked surfaces
  • Learn about the dynamics of vehicles in motion, particularly lateral acceleration limits
  • Investigate real-world applications of banked curves in road design and racing
Physics students, automotive engineers, and anyone interested in the dynamics of vehicle motion and road design will benefit from this discussion.
mutineer123
I was wondering, if I were to drive in a flat road , and then on a banked road(steep), in a circular motion, which one would be more difficult to manoeuvre over. I thought of generalising the two, but obviously it won't work because in the flat road, it is the frictional force that acts as the centripetal force(while the normal force cancels the weight), while in the banked road, the horizontal component of the normal force acts as the centripetal force(does anyone what the friction does then?).
But anyhow, to measure the 'manoevurabilty', I was thinking of using the velocity, ( more of it, the harder it is to manoeuvre),and so would have used force=mv^2/r, but there was a flaw because like I said the force acting as centripetal are different in each case. So now I am thinking the 'ease with which the car turns in each case' as a measure of difficulty in manoeuvring. This depends on the magnitude of the centripetal force in each case. So i again used force=mv^2/r, this time keeping v constant. So I figured, out that it takes more force in the banked surface than in the flat, to maintain the same speed. Is this a good way to figure it out? or is there a better way? This is not really anything important, and purely a discussive question. I was just thinking bout it, and thought what would by fellow physicsforumers say about it...:)
If you guys do have a better way, let's discuss that! and btw I am an A level student and just started centripetal forces. So I know very little as of now.
Just so we stay on the same page. I took random variables, which were m of car=5kg, radius=2m, elevation of banked road=30 degrees.
I failed to grab your concept of 'manoeuvrability'. Could you give some more detail ?
In real life, I think curves are rated by the maximum speed you can have your car traveling without superceding certain limits in lateral acceleration or exceeding frictional forces or cabin sway or tumbling over or whatever. Anything like this ?
Friction stills helps provide centripetal force in the banked case. It's just that you need less of it, because there is a component of your weight that is parallel to the incline, that helps you out.
So one way to think about it is that the amount of available mv^2 / r has gone up in the banked case, allowing you to either take a tighter curve, or to take the same curve more quickly.
Guessing here, but I think you're saying that steering becomes more difficult when there's a large lateral frictional force. The size of that force is whatever's needed to make the total with gravity and normal force equal to the centripetal force. With a bank angle of θ, circle radius r, speed v: F = m(v2 cos(θ)/r - g sin(θ)). Note that this will be negative if the bank is steeper than ideal for the speed.
Yes, this is the type of answers, I am loooking for. Theyre easy to understand, and is in the same line of my thinking! But i have a question
'because there is a component of your weight that is parallel to the incline, that helps you out.'
How exactly does Mg(weight) have a component parallel to the incline. I posted a free body diagram, and correct me if I am wrong. Isn't the weight canceled by the Y component of the normal force (N) ?, so how does the weight have a component, let alone one that is parallel to the slope.
heres the diagram - http://tinypic.com/view.php?pic=xct950&s=6
Well its just a rough variable, think of you driving in a constant circular motion. Once in a flat road and then in a banked road. If you were to keep all variables the same, velocity, road surface, tyre grip etc which terrain would you find easier to maintain the circular motion?
That diagram is not correct. The y-component of N does not fully cancel mg.
To see why, try doing this instead: you can resolve mg into components that are parallel to and perpendicular to the incline.
The normal force can only act perpendicular to the incline.
Since there is no acceleration perpendicular to the incline, the net force in this direction must be 0 (Newton's second law). Therefore, the sum of the forces in the "perpendicular to the incline" direction must be zero. This tells you that N is equal (in magnitude) to the perpendicular component of the weight.
There is a net acceleration (and hence a net force) *parallel* to the incline (i.e. in the "down the hill" direction). This is equal to the parallel component of the weight, which is not balanced (cancelled) by anything.
  • · Replies 19 ·
  • · Replies 16 ·
  • · Replies 17 ·
