Comparing power output of Solar Panels/cells
The task involves comparing the power outputs of solar cells and solar panels. The original poster describes a setup where a circuit is used to measure the power of solar cells, while a beaker of water is heated to assess the output of solar panels.
  • Exploratory, Conceptual clarification, Problem interpretation
  • The original poster attempts to measure the power output of solar cells using a voltmeter and ammeter, questioning the necessity of a resistor and its effect on measurements. They also inquire about improving experimental accuracy and the relationship between water mass and volume. Other participants suggest connecting a load to measure current and voltage, and experimenting with different resistances to optimize power output. Additionally, there is a discussion about the influence of light wavelength on solar panel performance.
Participants are navigating assumptions about the experimental setup, including the role of resistors and the impact of light color and wavelength on solar panel efficiency. There is also a mention of homework constraints that may limit the scope of experimentation.
jonnyrocks
The task is to compare the power outputs of solar cells, and solar panels. For solar cells, a circuit is devised to work out the power, solar panels a beaker of water is heated.
Power=voltagextime
Q=mc(delta)T
Power=Energy/time
Here is a scan of my two circuits at the moment
(The link is in my signature, it won't let me post it here ;) 0
For the solar cell, i will use the voltmeter and ammeter to work out the power. However, not sure if a resistor is nnecessary, will it affect the measured output power?
Also, how would I make the experement more accurate? I've already got mirrors to reflect as much light as possible, but would making thew beaker black absorb more light? Aditionally, am I right in thinking that 100g of water = 100ml?
Finally, would I have to multiply the powewr output for the cells by the length of time the solar panel is heating?
Thanks very much!
Heres the scan:
To measure the the output of the solar cell you have to connect a load and measure the current that goes through it and the voltage across it. You have to try different resistances as load to see what the value of the load resistance is that maximizes the power.
Energy = Power * Time, so you do have to multiply the power of the solar cell to compare it to the heat added to the water.
Hi,
Solar cells generate an electrical current when light hits their surface. White light that we see from the Sun includes all colors of the visible spectrum and ranges in wavelength from about 400 nanometers (nm) to about 780 nm. Solar cells vary in their response to different wavelengths, or color, of light.
A solar panel will output different levels of power depending on the color and wavelength of the incoming light.
  • · Replies 38 ·
  • · Replies 31 ·
