Comparison between quantum entanglement and a classical version
In summary: But in the case of quantum entanglement, the correlations are still there--they're just due to the fact that the particles are related in a particular way.In summary, quantum entanglement is a profound way to maintain correlations between particles even when they are far apart.
  • #106
Adel Makram said:
Non locality means Bob particle changed to a definite spin state when Alice particle measured instantaneously according g to the collapse interpretation.
As others have pointed out - there's a problem with using some notion of collapse here. Is it Alice or Bob who collapses the state? The answer is that it could be either depending on the frame of reference. So there's something a bit wonky with this idea that measurement causes some state change (collapse) in this scenario.
But even so it's important to realize that the issue only occurs because of a particular interpretation we've placed on things and not really a feature of QM.
Strip away the interpretative fun and games and QM is a theory that links preparations with measurement results - that's all. It doesn't tell us what's "really" happening in between these two things in any definite sense. Some people advocate thinking of the state, or wavefunction, as merely an abstract mathematical device that possesses no physical reality. It just allows us to calculate correct measurement probabilities. When we make a measurement we gain new information and so our probabilities instantly change - nothing at all non-local or strange about that process.
The point is that we don't actually need collapse as a concept in QM and nor do we need to think of the state as being some real physical entity that evolves.
Having said that, my own personal preference is to think in terms of measurement-induced collapses of a real physical entity, because that's the easiest and most pragmatic way of thinking about QM for me. But even so, there is no real issue with non-locality since no physical observables are being changed or linked by anything FTL - in other words there are no non-local experimental consequences. Only this nebulous wavefunction or state (whatever this might be) changes instantaneously in this perspective.
Likes Nugatory
  • #107
Adel Makram said:
Non locality means Bob particle changed to a definite spin state when Alice particle measured instantaneously according to the collapse interpretation.
That is not what "non-locality" means.
Speaking loosely, non-locality refers to the fact that to calculate the result at either detector you need to know the settings of both detectors - any mathematical equation that correctly predicts the experimental results will include the angle between the two detectors somewhere. This non-locality does not necessarily conflict with relativity (although it will if you also assume wave function collapse, which is a good reason not to make that assumption).
Note that I did say "speaking loosely"... There are some subtleties here, and the Timson/Brown paper I linked above goes into them in more depth.
  • #108
morrobay said:
Also if probability of Bob measuring spin down = sin2 (β - Φ)/2)
And this formula is equated to 1/2 ( 1 - β ⋅ α ) above then can someone show this numerically also ?
It's just a trigonometric identity: [itex]sin^2(\frac{X}{2}) = \frac{1}{2}(1 - cos(X))[/itex]
  • #109
Adel Makram said:
Ok. So how SR explains the non locality then?
Well, that's what's tricky about QM. Although some interpretations (the collapse interpretation, the Bohm interpretation) involve faster than light interactions, there is no way to use QM to send a FTL signal, and so there is no way to use QM to demonstrate a violation of SR.
  • #110
I think it's also useful to realize that we don't actually need non-locality to see a violation of the statistical inequality we call Bell's inequality, and nor do we need entanglement. If that seems counter to everything you've read on Bell's inequality then consider the following :
In the usual scenario we have Alice <---------------- Source ----------------> Bob
Let's bring Alice closer to the source so that we have Alice <- Source ---------------->Bob
In both these cases when statistics are compared we see a violation of the BI (for appropriately chosen measurement angles)
Now let's put the source in Alice's lab. She doesn't allow any of the entangled particles to reach Bob, but she makes a measurement of one of the entangled particles as she would in the normal set-up. Now she uses the result she obtains to prepare another spin-1/2 particle and sends this off to Bob
So we have || Alice <- Source -> || ......Bob
then Alice ---------------->Bob
So in fact we don't need the entangled source at all - Alice can just randomly prepare spin-1/2 particles in the appropriate states.
Now when we compare the statistics there's a violation of the Bell inequality but it's between Alice's state preparation and Bob's measurement.
No problems with FTL signals here - and we don't need entangled particles - yet we're still seeing a violation of a mathematical inequality (the BI)
Of course this is a different experimental set-up which doesn't carry with it the same implications for 'reality' - and it was the brilliance of EPR and subsequently Bell to focus on a simple physical system that could bring out these implications for 'reality' - but it's not the 'non-local' bit of QM (or the entanglement) that's actually giving us mathematics capable of violating the mathematical inequality. A bit hard to state precisely, sorry, but I hope you get my drift here.
  • #111
So you are saying exactly what? Bell inequalities demonstrate that local hidden variable explanations are not viable for some experiments. Yours isn't one of them.
  • #112
Agreed :-)
I'm sorry I was hoping that I made it clear that this different experimental set-up doesn't have implications for reality in the same way that the usual Bell set-up does. My fault.
What I was trying to get at was that in both cases the maths is identical - just that we interpret it differently in each case. For me I think it brings out that the non-commutatitivity is driving the violation in QM - and when we apply this to the usual Bell set up we also get all these interesting implications for hidden variable theories.
In a nutshell there's nothing Bob can do even when given Alice's data to distinguish whether the results are from genuine entangled particles or Alice's state preparations. This has practical implications in that we can use this in a quantum key distribution using the Bell inequality protocol, but now with single particles instead of having to use entangled sources which are practically a bit trickier.
  • #113
I think there's also a sense in which the issue of non-locality is almost a red herring. That's a little bit of an overstatement and I hope the following will make it clearer what I mean.
If we impose the condition that results 'here' do not depend on settings 'there' even if here and there are only timelike separated, then a hidden variable theory of QM of this kind would satisfy the Bell inequality. We can't rule out a hidden variable theory of physics which did allow this. So even for timelike here and there we can rule out a certain class of local hidden variable theories.
So the possible candidate hidden variable theories are those in which information about settings 'there' is transferred to 'here' and affects results 'here'. I've not seen any of these constructions which look like anything like a 'sensible' theory of physics. They are possible, but somewhat artificial (at least the ones I've seen) - even in the local case where 'here' and 'there' are timelike separated. The Bohm theory, which is non-local anyway, has some attractive features and is perhaps the most 'natural' I've seen, but even there we have to introduce this complex guiding potential.
If anyone does know of a 'natural' local hidden variable theory that works (i.e. violates the BI) in this more restricted timelike case - then I'd love to see it if you have a link.
So in my view 'classical' physics is struggling even before we hit the issue of non-locality. In this case then I think it's useful to figure out what it is about QM that's causing the violation - even in the local case which only rules out a more restricted class of local hidden variable theories.
Of course it's critical that we go that last step and consider spacelike separated 'here' and 'there' - and then we put the final nail in the coffin of local hidden variable theories.
Likes Nugatory and Mentz114
  • #114
So what class of local hidden variables that satisfies BI in a time-like experiment?
  • #115
Any theory in which the result at either detector depends on the initial state (hidden and unhidden variables) of the particle pair and on the state (hidden and unhidden variables) of that detector at the time detection will satisfy the inequality - that IS the theorem, restated in layman's language, as the theorem derives the inequality from the premise that the theory is as I just said. The timelike or spacelike separation of the measurement events is irrelevant to this proof.
  • #116
Will the quantum correlation be reproduced by putting 2 polarizers with opposite direction between the source and the detectors (one polarizer at each side of the source that pass only spin up along its direction) and repeating the experiments at different angles of both polarizers near the source and the polarizers at Alice and Bob?
Let`s put 2 polarizers, one on each side of the source, Ptoward Alice ( between the source and Alice) and Ptoward Bob ( between the source and Bob). The two polarizer are in opposite direction and they only pass spin-up along their respective direction so that the spin-up( up in the +ve Z direction) from Ptoward Alice is accompanied by spin-down (-ve Z) from Ptoward Bob.
Then Alice and Bob are measuring their spins at their detectors/polarizers as in standard Bell`s experiment with different angles of their detectors and compare their results. Will they come to a quantum correlation?
Let`s repeat the experiment by rotation the polarizers-set at many angles from 0 to 2π ( but always keeping them at opposite direction) and compare results again. Will the result be in keeping with quantum correlation?
Clearly the BI will be violated if we only compare Ptoward Alice with the detector/polarizer at Bob or Ptoward Bob with the detector/polarizer at Alice but how about the correlation between Alice and Bob outcomes?
On one hand, the correlation between Alice and Bob would be classical in nature because the spin status has been already collapsed at the polarizer near the source and the results at Alice and Bob places will be independent as if there would be taken at two non-entanged spins at different places.
On the other hand, the orientation of spins reaching Alice and Bob will be always in opposite direction and repeating experiment at different angles of the polarizer-set at the source with no information about which angle is choozen might be similar to the fully entanglement status which should mandate results in keeping with quantum correlation.
So where did I go wrong?
  • #117
Alice's measurements will depend on the angle between her detector and the filtering device on her side, but not on Bob's settings. Likewise, Bob's results will depend on the angle between his detector and the filtering device on his side, but not on Alice's settings.
(You said "polarizer" but you're talking about particle spins not polarizations, so a polarizer is the wrong device to achieve your purpose. You need something like a Stern-Gerlach device, which deflects particles with spin-up along its axis in one direction and spin-down in the opposite direction).
Likes Adel Makram
  • #118
So the correlation between Alice and Bob measurements will be classical.
But considering that both sides know nothing about the angle of the filtering device near the source relative to z-axis which is changing at random for each pair. This would simulate the mixed state of fully entangled particles, I expect the correlation to follow quantum mechanics prediction.
  • #119
The probability of Alice and Bob getting the same result will not be ##\sin^2\frac{\alpha-\beta}{2}##. Bob and Alice will find this out when they get together afterwards and compare the results of their measurements.
  • #120
It will not simulate an entangled state at all. The stats may match at selectively chosen angles, but that's it. One is product state stats, the other is entangled state stats.
Likes Adel Makram
  • #121
In order for there to be conservation of momentum the downconverted photon pair are created with opposite angular momentums.
Each of the pair can determine the position and momentum of the other based upon their own position and momentum.
Entanglement is each of the pair being able to determine the state of the other.
They are not physically or superluminally connected.
Their ability to determine each other's state is non-local.
  • #122
Welcome to PhysicsForums, mpc755!
There are QM interpretations that include such a remote connection. The underlying physical nature of entanglement of remote particles is something of a mystery.
  • #123
Thanks!
Those interpretations are incorrect.
It's not a mystery. Entanglement is each of the pair being able to determine the other's state based upon their own position and momentum.
  • #124
I guess mystery is in the eye of the beholder.
So I would ask, according to your line of reasoning: If I measure Alice's p, is entangled partner Bob's q indefinite? Because Alice's is. If I measure Alice's q, is Bob's p indefinite? Because Alice's is. If so, does the nature of a measurement on Alice change Bob? This is a bit of a mystery to myself and most.
  • #125
Alice's measurement is indefinite to you. It's not indefinite to Alice or Bob.
The nature of measurement on Alice does not change Bob. They are propagating with opposite angular momentums.
Yes, because no one realized you have to understand entanglement from the point of view of Alice and Bob, not an external observer performing the measurement.
  • #126
mpc755 said:
Alice's measurement is indefinite to you. It's not indefinite to Alice or Bob. The nature of measurement on Alice does not change Bob. They are propagating with opposite angular momentums. Yes, because no one realized you have to understand entanglement from the point of view of Alice and Bob, not an external observer performing the measurement.
What you are saying sounds suspiciously like the argument of a local realist. Hopefully I am misunderstanding you, because such is prohibited by Bell's Theorem. You are familiar with this, correct?
I can predict Bob's spin at any angle across the spectrum by measuring Alice. If Alice and Bob are independent, as you imply, and there is no superluminal interaction, as you also imply, then Bob's spin at any angle across the spectrum must actually be predetermined. (Which is contradicted by Bell tests.)
  • #127
We have many threads on the validity of quantum mechanical interpretations already; we don't need another one. There is no experimental basis for a flat assertion that some interpretations are simply incorrect.
Continued discussion of how Bell's theorem precludes an explanation of the type that mpc755 is advancing is welcome (although it would be good to first review the background of Bell's theorem including the material at http://www.drchinese.com/Bells_Theorem.htm and many other threads here).
  • #128
OK, thread is open to all again.
  • #129
Bell's theorem precludes local hidden variable theories. I am discussing a non-local hidden variable theory.
If Alice and Bob are a downconverted photon pair then they are propagating with opposite angular momentums.
The 'non-local' aspect of entanglement is the ability of Alice and Bob to know what they themselves and each other will be detected as based upon their own position and angular momentum.
They can determine each other's spin. Their spins are deterministic to each other.
This does not contradict Bell's Theorem as their ability to determine each other's spin is non-local.
  • #130
To be consistent with the observed violation of Bell's inequality, you need an additional assumption - not only are the angular momenta opposite, but also the direction is not set (note that I said "set", not "discovered" or "known") until the first measurement is made.
Likes Adel Makram
  • #131
When Alice and Bob are created they both know the direction they are traveling. They are both able to determine the direction they are traveling from their point of origin. Due to conservation of momentum they are propagating with opposite angular momentums. Alice and Bob are able to determine each other's location and calculate what it will be in the future based upon their own angular momentum.
  • #132
They can. However those calculations don't match what happens when we actually do the experiment.
  • #133
mpc755: You seem to call the particles "Alice" and "Bob". In the Bell-terminology, Alice and Bob are hypothetical observers, and the particles are not usually elevated to a status where they are named.
  • #134
They will if they use the calculations of quantum mechanics and not classical physics.
  • #135
Okay, Photon1 and Photon2 then. Thanks.
Photon1 and Photon2 know their angular momentum from the time of their creation. They can also determine their pair's position and momentum based upon their own position and momentum because they know they are each propagating with opposite angular momentums.
Their position and momentum are not hidden from one another.
Their states are exposed to one another.
Entanglement is more correctly described as an 'exposed variable theory'.
  • #136
But the calculations of quantum mechanics include the assumption that the direction of spin is set by the first measurement. The quantum mechanical calculation of the probability distribution of Bob's results depends not just on what he knows about Alice's particle and his particle, but also on Alice's choice of measurement direction (made long after the photon pair is created).
  • #137
So if A is the product state of two particles U1 and U2, then A=U1⊗U2.
U11uu1dd
U22uu2dd, where u and d are basis vectors.
A=U1⊗U2=(α1uu1dd)(α2uu2dd)
= α1uα2uuu1uβ2dud1dα2udu1dβ2ddd
If we prepare particles with opposite momenta to each other by putting filtering devices at each side of the source with opposite direction then,
Only the coefficients with states ud, du should be only non-zero which should reduce the state into an entangled state with proper normalization ( multiplying by 1/√2). A=1/√2(ud+du)
  • #138
Even if Photon1 does not know what Photon2's measurement direction will be Photon1 can still determine what the spin will be detected as ahead of time. Photon1 can calculate if Photon2 is detected with such-and-such measurement direction then it will have this spin. It's still deterministic.
  • #139
What is the difference between "set" and "known"?
In general what is the real difference between entangled particles and two prepared particles with opposite momenta and unknown direction relative to +z-axis?
1) The 2 entangled particles have always opposite angular momenta so do prepared particles.
2) The state of each of entangled particle is in superposition of spin-up and down with 50-50 chance, so do prepared particles (because Alice for example, will have an expected value of spin measured along her direction =1/2π∫cos2(θ/2)dθ (the interval 0 to 2π)=1/2 provided all angles of prepared particles are included by rotating the filtering device at the source at random).
  • #140
You will have something that is in a superposition of ud + du, true enough. But only at special angles. Those being related to whatever angle you filtered at. Any other angle will be some combination of uu + ud + dd +du. It's a Product State, after all.
On the other hand, entangled states will maintain the ud + du superposition at any angle.
So no, they are not at all alike and I have no idea why you think they would be. This goes blatantly against everything ever written (at least that can be referenced here).
<h2>1. What is the difference between quantum entanglement and a classical version?</h2><p>Quantum entanglement refers to the phenomenon where two or more particles become connected in such a way that the state of one particle is dependent on the state of the other, regardless of the distance between them. In contrast, a classical version of entanglement would involve macroscopic objects and their states would be determined by classical physical laws.</p><h2>2. How does quantum entanglement work?</h2><p>In quantum entanglement, two particles are created in a way that their properties are correlated. This means that measuring the properties of one particle will instantly determine the properties of the other, regardless of the distance between them. This phenomenon is still not fully understood and is a subject of ongoing research.</p><h2>3. Can quantum entanglement be used for communication?</h2><p>While quantum entanglement allows for instantaneous correlation between particles, it cannot be used for communication in the traditional sense. This is because the state of the particles cannot be controlled or manipulated to send a specific message. However, it can be used for secure communication through quantum cryptography.</p><h2>4. How is quantum entanglement different from classical correlations?</h2><p>In classical correlations, the relationship between two particles is determined by classical physical laws, and the state of one particle can be predicted by measuring the state of the other. In quantum entanglement, the relationship between particles is based on quantum mechanics, and the state of one particle cannot be predicted by measuring the state of the other.</p><h2>5. What are the potential applications of quantum entanglement?</h2><p>Quantum entanglement has potential applications in quantum computing, quantum cryptography, and quantum teleportation. It also plays a crucial role in understanding the foundations of quantum mechanics and could potentially lead to new technologies in the future.</p>
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
