How Do Starting Points Affect Series Comparison Tests?
  • Context: Graduate
  • Thread starter Thread starter PFuser1232
    Comparison Series
The discussion centers on the impact of starting points in series comparison tests, specifically the Comparison Test and the Limit Comparison Test. It establishes that for two series, ##\sum a_n## and ##\sum b_n##, if ##a_n \leq b_n## and ##\sum b_n## converges, then ##\sum a_n## also converges. The Limit Comparison Test confirms that if the limit ##c = \lim_{n \rightarrow \infty} \frac{a_n}{b_n}## is positive and finite, both series will either converge or diverge together. The consensus is that differing starting points do not affect the outcome, as one can adjust the series to have the same starting point by removing a finite number of terms.
  • Understanding of infinite series and convergence
  • Familiarity with the Comparison Test and Limit Comparison Test
  • Knowledge of limits in calculus
  • Ability to manipulate series indices
  • Study the Comparison Test in detail, focusing on its conditions and applications
  • Explore the Limit Comparison Test and its implications for series convergence
  • Learn about manipulating series indices to align starting points
  • Review examples of series that demonstrate the effects of starting points on convergence
Mathematics students, educators, and anyone studying series convergence, particularly those interested in advanced calculus and analysis.
PFuser1232
Comparison Test
Consider the two infinite series ##\sum a_n## and ##\sum b_n## with ##a_n,b_n \geq 0## and ##a_n \leq b_n## for all ##n##.
If ##\sum b_n## is convergent so is ##\sum a_n##.
If ##\sum a_n## is divergent so is ##\sum b_n##.
Consider the two infinite series ##\sum a_n## and ##\sum b_n## with ##a_n \geq 0## and ##b_n > 0## for all ##n##. Define:
$$c = \lim_{n \rightarrow \infty} \frac{a_n}{b_n}$$
If ##c## is positive and finite then either both series converge or both series diverge.
Does it matter if the two series we're comparing have different starting points? I don't think it matters because we can always strip out a finite number of terms from one of the series until both series have the same starting point.
http://tutorial.math.lamar.edu/Classes/CalcII/SeriesCompTest.aspx
But according to this link, "in order to apply this test we need both series to start at the same place."
You are removing a finite number of terms because you care about different starting points.
Sometimes it possible to change index in order to have series from a determinate point, as example from ##\sum_{i=1}^{\infty}a_{i}## putting ##i-1=k## we have ## \sum_{k=0}^{\infty}a_{k+1}##...
The limit is as ##n \to \infty##, so the starting points of the two series don't matter.
