Comples analysis - Radius of convergence of a Taylor series question
6 replies · 3K views
Pyroadept
Find the radius of convergence of the Taylor series at z = 1 of the function:
[itex]\frac{1}{e^{z}-1}[/itex]
Hi everyone,
Here's what I've done so far.
Multiply top and bottom by minus 1 to get:
-1/(1-e^z)
And then this is the expansion of an infinite geometric series:
1/(1-z) = Ʃ(z^n)
Then use the formula 1/R = lim sup (nth root of absolute value of a_n)
where here a_n is constant, 1.
So then you will get that the lim sup of this is 1.
So then R = 1.
However, I don't like this solution as I think that geometric formula only applies if |z|<1, which is not the case for e^z.
I am a bit stuck as to how else to write out the Taylor series though. And how do I make use of the fact z=1? Does that mean I have to write out a Taylor series in the form Ʃa_n.(z-1)^n?
I'd really appreciate if someone could please point me in the right direction.
Thanks
You want to find the radius of convergence of the series of the form [itex]\sum_{n=0}^{\infty} a_n (z-1)^n[/itex], yes. Don't bother looking at the series itself though. Just use the fact that the radius of convergence of a Taylor series is just the distance from its center to the nearest singularity. Where are the singularities of [itex]\frac{1}{e^z - 1}[/itex]?
Thanks for your reply!
Ah. So the singularity would be at z=0 then?
So the distance from z=0 to z=1 would be 1, so the radius of convergence is then R=1 centered at the point z=1?
Also, just out of interest, how exactly would you write that formula as a power/Laurent series?
That's the closest singularity, yes. But for future reference, remember that there are also other singularities at [itex]2\pi ik[/itex] for every [itex]k\in \mathbb{Z}[/itex].
Yep. You got it!
It's easy enough to find the Taylor series of [itex]e^z - 1[/itex] directly, and then you can just use long division to get the terms of the Taylor series for [itex]\frac{1}{e^z-1}[/itex]. It's a pretty tedious calculation though.
If you restrict values of z so that ##\left|\frac{1}{e^z}\right| < 1##,
\begin{eqnarray*}
\displaystyle \frac{1}{e^z - 1} &=& \left(\frac{1}{e^z}\right)\left(\frac{1}{1-\frac{1}{e^z}}\right)\\
&=& \left(\frac{1}{e^z}\right) \cdot \sum_{n=0}^{\infty} \left(\frac{1}{e^z}\right)^n\\
&=& \sum_{n=0}^{\infty} \left(\frac{1}{e^z}\right)^{n+1}\\
&=& \sum_{n=0}^{\infty} (e^z)^{-n-1}\\
&=& \sum_{n=-\infty}^{0} (e^z)^{n-1}\\
&=& \sum_{n=-\infty}^{-1} (e^z)^n
\end{eqnarray*}
Edit: I just realized this isn't in power series form, you need a ##(z-a)^n##.. I'll leave this here because it's a good technique anyway. Yeah, it would be tough to put it into power series form.
