Complex Analysis - find v given u
6 replies · 2K views
Let f = u + iv be analytic. Find v for given u.
\begin{align*}
u &= \frac{x}{x^2+y^2} = x (x^2+y^2)^{-1} \\
\rule{0mm}{18pt} \frac{\partial u}{\partial x} &= \frac{\partial v}{\partial y}
\qquad\qquad \frac{\partial u}{\partial y} = -\frac{\partial v}{\partial x}
\end{align*}
Solution Attempt:
\begin{align}
\frac{\partial u}{\partial x} &= \frac{\partial v}{\partial y} = (x^2+y^2)^{-1} -x (x^2+y^2)^{-2} (2x)
= (x^2+y^2)^{-1} - 2x^2 (x^2+y^2)^{-2}
\rule{0mm}{18pt} \frac{\partial u}{\partial y} &= -\frac{\partial v}{\partial x} = -x (x^2+y^2)^{-2} (2y) = -2xy(x^2+y^2)^{-2}
\rule{0mm}{18pt} \frac{\partial v}{\partial x} &= 2xy(x^2+y^2)^{-2}
\rule{0mm}{18pt} v &= -y(x^2+y^2)^{-1} + g(y)
\rule{0mm}{18pt} \frac{\partial v}{\partial x} &= y(x^2+y^2)^{-2} (2x)
= 2xy(x^2+y^2)^{-2} \qquad \checkmark
\rule{0mm}{18pt} \frac{\partial v}{\partial y} &= -(x^2+y^2)^{-1} + 2y^2 (x^2+y^2)^{-2} + g'(y)
\end{align}
Equating (1) and (6):
\begin{equation}
-(x^2+y^2)^{-1} + 2y^2 (x^2+y^2)^{-2} + g'(y) = (x^2+y^2)^{-1} - 2x^2 (x^2+y^2)^{-2}
\end{equation}
I get stuck at the last step. I can't see any function of y that would satisfy the equation. What am I doing wrong?
##g'(y)=0##?
I don't know if this is in the spirit of what is expected for solving the problem, but:
##\frac {x}{x^2+y^2}## is the real part of ##\frac {1}{x+iy}## which is analytic except at ##z=0##.
The real and imaginary parts of ##\frac {1}{x+iy}## are easily found by multiplying both numerator and denominator by the conjugate, ##x-iy##.
Oh no! You did everything right and stopped a little too soon. Try ##g(y) \equiv 0##.
PeroK said:
Also, it would have been better if you had simplified:
$$\frac{\partial u}{\partial x} = \frac{y^2 - x^2}{(x^2 + y^2)^2}$$
I agree. It is hard to recognize things as done in the OP.
When taking the derivative of a quotient, I like to use the quotient rule rhyme:
If the quotient rule you wish to know,
It's low D-high less high D-low.
Draw a line and down below
The denominator squared must go.
Drat, I see it now. Thanks!
\begin{align*}
\frac{y^2-x^2}{(x^2+y^2)^2} &= \frac{y^2-x^2}{(x^2+y^2)^2} + g'(y) \\
\rule{0mm}{18pt} g'(y) & = 0 \\
\therefore v &= \frac{-y}{x^2+y^2} + C
\end{align*}
