Complex contour integral, which one do I use?
- Level: Graduate
- Thread starter hunt_mat
- Start date
28 replies · 8K views · last reply
Discussion
Charles49
- 87
- 0
You need a semi-circle where the diameter is on the right (from your perspective) of the poles [tex]\pm a[/tex]. That's easier to work with.
Homework Helper
- 1,818
- 33
I am aware of the Bromwhich contour for the Laplace transform. Do I need to cut to disks out at [itex]\pm a[/itex] to make a double keyhole if you like?
Also if a is complex do I need to do the same thing? What about a slightly function?
[tex] \lim_{R\rightarrow\infty}\int_{\sigma -Ri}^{\sigma +Ri}\frac{e^{sx}}{(s-b)\sqrt{s^{2}-a^{2}}}ds[/tex]
where b is real. Do I need the keyhole contour again?
Homework Helper
- 1,818
- 33
This is the contour that you would usually use if there are any singularities on the real line but what is you singularities move? I have a value which moves from being completely real (hence the need for a keyhole contour shown to one being complex and I can just take a semi-circle.
Suggestions?
Mat
Suggestions?
Mat
Charles49
- 87
- 0
See figure 4.1.6 in page 315 of http://books.google.com/books?id=Y6...v=onepage&q=duffy integral transforms&f=false
Charles49
- 87
- 0
It doesn't matter if the pole is real or complex. You just move the location of the keyhole to circumvent the value. If there are more poles, you simple include more keyholes.
I included the link because the parts you are interested in is free to view in Google Books.
jackmell
- 1,806
- 54
hunt_mat said:I want to perform the following integral which comes from inverting a Laplace transform:
[tex] \lim_{R\rightarrow\infty}\int_{\sigma -Ri}^{\sigma +Ri}\frac{e^{sx}}{\sqrt{s^2-a^{2}}}ds[/tex]
Would it be some kind of keyhole contour?
Mat
I believe direct contour integration is going to be tough. How about a different approach? Solve an easy one, get the answer (via Mathematica), then justify that answer. Then generalize it to arbitrary values of the parameter. Ok, let me try without helping you too much. Say:
[tex]\mathcal{L}^{-1}\left\{\frac{1}{\sqrt{s^2-1}}\right\}=\text{BesselJ[0,ix]}[/tex]
Now, we know:
[tex]\text{BesselJ[0,ix]}=\frac{1}{2\pi i}\oint{e^{ix/2(t-1/t)}1/t dt}[/tex]
So, if you're interested, can you come up with a suitable change of variable (and subsequent change of contour) and justify saying:
[tex]\frac{1}{2\pi i}\int_{\sigma-i\infty}^{\sigma+i\infty}\frac{e^{sx}}{\sqrt{s^2-1}}ds=\frac{1}{2\pi i}\oint{e^{ix/2(t-1/t)}1/t dt}=\text{BesselJ[0,ix]}[/tex]
I've not (completely) proven this and would personally find it a challenge to do so. Maybe though, you may wish to pursue it.
jackmell
- 1,806
- 54
If you wish to integrate it directly, then I think you need to use a dumb-bell contour around the branch points [itex]\pm a[/itex] enclosed inside a larger closed contour which includes the Bromwich path. These two contours then traverse an entirely analytic function so they are equal to one another and I think the dumb-bell contour is not too difficult to analyze. The reason I suggest that is because the Riemann surface for n'th roots of n'th degree polynomials are analytic outside the hull of polynomial zeros. I barely understand it myself for that matter. Tell you what, when I do that for the simple case I used above, I obtain:
[tex]\int_{1}^{-1}\frac{e^{r x}+e^{-{rx}}}{\sqrt{r^2-1}}dr[/tex]
and that integral can be written in terms of [itex]\text{BesselJ[0,ix]}[/itex]
however, I've not analyzed the remaining parts of the contour to justifiy equating that answer as the inverse transform.
jackmell
- 1,806
- 54
hunt_mat said:can anyone lend a hand or spot where I have made a mistake?
. . . that's not the correct contour to use although it may turn out to give you the correct answer or maybe the neg of the answer because it's computationally similar to what I said earlier. However, using it to solve this problem in my opinion clearly indicates a lack of understanding of the underlying Riemann geometry. No offense ok. It's just if you don't understand that geometry for this one, then you'll have problems solving others like it that likely will not be so forgiving if you use the wrong contour.
Homework Helper
- 1,818
- 33
My Riemannian geometry isn't bad (I have an MSc in it from Oxford university in geometry) but I don't see how it pertains to this problem.
Let us examine the reason why the contour may be a good one to use. First off, for the inverse Laplace transform, the Bromwich contour, so whatever contour id used, it must be a deformation of this in some way. There is a square root involved, so there must be a branch cut of some kind, so a branch cut is taken from -a to +a and the contour is deformed around the two branch points, so that is what I did.
As I homework helper, I am always polite and helpful. I am never condescending to any of the people I help out. I would ask you to do the same.
jackmell
- 1,806
- 54
hunt_mat said:My Riemannian geometry isn't bad (I have an MSc in it from Oxford university in geometry) but I don't see how it pertains to this problem.
I did not feel I was being condenscending. Actually I thought I was being quite polite. Sorry if I came across that way. Also, I should have said, "Riemann surface" and not Riemann geometry. The two legs you have going from -infty to -b are completely unnecessary. The function is analytic there so you can just cross-over the negative imaginary axis with one big circular contour (which includes the Bromwich path) and equate that contour it to the remaining "dumb-bell" contour going around the two branch-points unless the pole at a is "between" the two contours in which case you'd have to adjust the calculation to include that pole. I stand by what I said: in order to do well integrating over multifunctions, I believe it's essential to have a good understanding of the underlying Riemann surfaces that are being integrated over and understanding why you can delete the two "excipient" legs from -infty to -b is one way to exhibit such an understanding.
Also, unless you know what the answer is, I suggest you numerically integrate over the Bromwich path for some value of x and compare that with the inverse transform expression you obtain. If these agree, then I think it's a very good indication your answer is correct.
Charles49
- 87
- 0
I am assuming a and b are real. Also is a>b or is b>a?
Charles49
- 87
- 0
I couldn't evaluate the integral you posted using Mathematica. I suggest that the inverse you want is the convolution of [tex]BesselJ[0, i a t][/tex] and [tex]e^{b t}[/tex] where BesselJ is the Bessel function of the first kind. The convolution is defined as [tex]f*g=\int_0^t f(y)g(t-y)dy.[/tex] This follows from the convolution theorem which says that the product of functions in the s domain equals to the Laplace transform of the convolution of the inverse Laplace transform of the individual factors.
jackmell
- 1,806
- 54
Charles49 said:I couldn't evaluate the integral you posted using Mathematica. I suggest that the inverse you want is the convolution of [tex]BesselJ[0, i a t][/tex] and [tex]e^{a t}[/tex] where BesselJ is the Bessel function of the first kind. The convolution is defined as [tex]f*g=\int_0^t f(y)g(t-y)dy.[/tex] This follows from the convolution theorem which says that the product of functions in the s domain equals to the Laplace transform of the convolution of the inverse Laplace transform of the individual factors.
Does that answer agree with the numerical result:
Code:
In[16]:=
a = 2;
b = 1;
x = 1;
NIntegrate[(1/(2*Pi*I))*((I*Exp[s x])/
((s - a)*Sqrt[s^2 - b^2])) /. s -> 3 + I*y,
{y, -250, 250}]
Out[19]= 3.34859 + 4.35036*10^-15 I
Charles49
- 87
- 0
jackmell said:Does that answer agree with the numerical result:
Code:In[16]:= a = 2; b = 1; x = 1; NIntegrate[(1/(2*Pi*I))*((I*Exp[s x])/ ((s - a)*Sqrt[s^2 - b^2])) /. s -> 3 + I*y, {y, -250, 250}] Out[19]= 3.34859 + 4.35036*10^-15 I
No, it doesn't. How did you get s=3+iy?
jackmell
- 1,806
- 54
Charles49 said:No, it doesn't. How did you get s=3+iy?
The value of [itex]\sigma=3[/itex] for [itex]s=\sigma+it[/itex] is arbitrary as long as it's to the right of any singularities although the particular value will affect the rate of convergence of the numerical results. Also, I just arbitrarily stopped the integration at [itex]\pm 250[/itex]. Generally with these, you sequentially bump up the path length until you observe some sort of limiting value for the integral. It wasn't changing much at 250 so I stopped. Also, I do obtain that (approx) answer with numerically integrating the convolution:
Code:
In[41]:= NIntegrate[BesselJ[0, I u] Exp[2 (1 - u)], {u, 0, 1}]
Out[41]= 3.34849 + 0. I
When I said "agree" I meant "close" right? That's pretty close so just with that calculation, I would have pretty good confidence the convolution is the inverse transform (without actually knowing for a fact it is).
Homework Helper
- 1,818
- 33
If you read the pdf of my calculations, I say why the two integrals vanish. I didn't just come up with this idea off the top of my head, I read various book on complex analysis (Riemannian geometry doesn't come into it) and adapted the analysis that they gave for their calculations to the one I presented in my notes.
As a reference for the complex analysis required I used "Introduction to complex analysis" by H.A. Priestly who gives examples of computing inverse Laplace transforms.
jackmell
- 1,806
- 54
hunt_mat said:If you read the pdf of my calculations, I say why the two integrals vanish. I didn't just come up with this idea off the top of my head, I read various book on complex analysis (Riemannian geometry doesn't come into it) and adapted the analysis that they gave for their calculations to the one I presented in my notes.
I apologize for offending you Hunt. Also, I probably should not have said, "not the right contour". It's an acceptable contour that is not incorrect. Now that myself and Charlie have established with high confidence what the inverse transform is, you now need only confirm that your analytical results agree.
Homework Helper
- 1,818
- 33
I ran it through Maple and I got the result:
[tex] e^{2t}\int_{0}^{t}I_{0}(u)e^{-2u}du[/tex]
However this is a warm up problem and the real problem is find the inverse Laplace transform of:
[tex] \frac{e^{as\pm\sqrt{s^{2}-b^{2}}}}{(s-c)(s-d)\sqrt{s^{2}-b^{2}}}[/tex]
Charles49
- 87
- 0
Hey Hunt, the contour you used is definitely wrong if [tex]a[/tex] is complex. I know this because, the contour must have keyholes which have positive or negative imaginary parts (depending on where [tex]a[/tex] is located). However, on the contour that you used, the keyholes are located on the real axis. By the way, just to avoid confusion as to which [tex]a[/tex] we are talking about, forget about the new problem, I'm still looking at the pdf you attached.
To get the Bromwich contour, look at all the singularities of the function you are dealing with. Plot them on the complex plane. Then look for a the line which is greater than the real parts of all the singularities of the poles. It doesn't matter how far away this line is or how close as long as it is to the right of the poles. Then try to draw the fewest number of keyholes around the poles with the contour going in the counterclockwise direction. Remember this: If you are walking along the contour you must see the poles on your right hand side. Then use the Cauchy residue theorem like you did before.
NBagley119
- 11
- 0
Three words I'd like to add to the discussion: Cauchy... Residue... Theorem...
Homework Helper
- 1,818
- 33
I thought I could just deal with [itex]a[/itex] in the normal way if it was complex, it isn't a branch point in any way, it's just a simple pole. Having taken you suggestion to heart, I sketched the contour which I think you mean. Is this the correct contour now? I have a feeling that the integral around the pole a will vanish but I will be left with contributions from the paths to and from the point?Charles49 said:Hey Hunt, the contour you used is definitely wrong if [tex]a[/tex] is complex. I know this because, the contour must have keyholes which have positive or negative imaginary parts (depending on where [tex]a[/tex] is located). However, on the contour that you used, the keyholes are located on the real axis. By the way, just to avoid confusion as to which [tex]a[/tex] we are talking about, forget about the new problem, I'm still looking at the pdf you attached.
Charles49
- 87
- 0
OK, try this and I'll check numerically the integral you get with the convolution I got.
- matt_crouch
- · Replies 5 ·
- Calculus
- Replies
- 5
- riemannian
- · Replies 2 ·
- Calculus
- Replies
- 2
- Poirot
- · Replies 3 ·
- Calculus and Beyond Homework Help
- Replies
- 3
- Nikitin
- · Replies 1 ·
- Replies
- 1
- Amad27
- · Replies 1 ·
- Replies
- 1
- Finnjessy
- · Replies 2 ·
- Replies
- 2
- Amad27
- · Replies 24 ·
- Topology and Analysis
- Replies
- 24
- c0nfig
- · Replies 4 ·
- Replies
- 4
- kreil
- · Replies 2 ·
- Replies
- 2
- ijustlost
- · Replies 4 ·
- Replies
- 4
