How do I solve complex contour integrals in complex analysis?
To solve complex contour integrals, it's essential to define the contour accurately, as it determines which poles are enclosed. The residue theorem is a key tool, allowing the evaluation of integrals by summing the residues at the poles within the contour. For a second-order pole, the residue can be calculated using a specific formula, which involves taking the derivative of the function multiplied by the squared term of the pole. Visualizing the contour and understanding the winding direction around the poles is crucial for applying the theorem correctly. The discussion emphasizes the importance of grounding oneself in the definitions and methods of contour integration before advancing to more complex applications.
matt_crouch
I am trying to teach myself complex analysis . There seems to be multiple ways of achieving the same thing and I am unsure on which approach to take, I am also struggling to visualise the problem...Would someone show me step by step how to solve for example
$$\int_{\Gamma}\frac{2\lambda}{[(\lambda-\lambda_{+})(\lambda-\lambda_{-})]^{2}}\frac{d\lambda}{i}$$
where ##\lambda_{+}, \ \ \lambda_{-}## are the roots given by
##\lambda_{\pm}=\frac{-i\zeta\pm ir}{q}##
So i believe the answer should be ##\frac{x}{r^{3}}## or something like that but I can't get there. Could someone show me how to approach a problem like this... Like visualise the contour etc
Do you know how the contour ##\Gamma## is defined? Should we assume that the roots, ##\gamma_{-}## and ##\gamma_{+}## are enclosed by the contour?
If they are then use the residue theorem to solve. It is very difficult to help you visualize a contour that is not defined.
Cauchy's Residue Theorem tells you that
##\int_\Gamma f(\gamma) \, d\gamma = 2\pi i \sum_{a \in \text{poles}}\mathrm{Res}(f,a)##
You already have the roots.
You should see that the poles are second order in this function, so use the higher order residue formula:
(From Wikipedia's page on Residue_(complex_analysis))
More generally, if c is a pole of order n, then the residue of f around z = c can be found by the formula:
For a 2nd order pole, this is simply
##\mathrm{Res}(f,a)=\lim_{\gamma \to a} \frac{d}{d\gamma} (\gamma - a)^2 f(\gamma) ##
Next, find the residues for ##\gamma_+## and ##\gamma_-##:
##\mathrm{Res}(f,\gamma_+)=\lim_{\gamma \to \gamma_+} \frac{d}{d\gamma}\left[ (\gamma-\gamma_+)^2\frac{2\gamma}{ i (\gamma-\gamma_+)^2 (\gamma-\gamma_-)^2}\right]##
Simplifying and taking the derivative, you get:
##\mathrm{Res}(f,\gamma_+)=\lim_{\gamma \to \gamma_+}\frac{2(\gamma_- +\gamma) }{i (\gamma_- - \gamma)^3 }=\frac{2(\gamma_- +\gamma_+) }{i (\gamma_- - \gamma_+)^3 }##
Due to the symmetry, you will get something very similar for ##\mathrm{Res}(f,\gamma_-)##.
Then, you plug in the expression you have for ##\gamma_+ , \gamma_-## to simplify even more.
Finally, you use the residue theorem to give you that the integral is equal to ##2\pi i ( \mathrm{Res}(f,\gamma_+)+\mathrm{Res}(f,\gamma_-))##.
And you are done.
Likes matt_crouch and zinq
RUber's post should be very helpful. The most important point is that you can't even begin to think about a complex contour integral without knowing what contour you are integrating around.
If you are just beginning to learn about contour integrals, it's probably a good idea to do some "by hand" — i.e., just going back to the definitions — before graduating to the extremely useful method of residues.
For instance, suppose you want to integrate f(z) = 1/z about the contour given by the unit circle C about the origin in ℂ. So: parametrize the contour C, by say
z(t) = eit, 0 ≤ t ≤ 2π,​
which turns the original integral
C dz/z​
into
∫ (1/eit) i eit dt = ∫ i dt​
(where the integral is from t = 0 to t = 2π) , since dz = i eit dt.
Thus we have shown
C dz/z = 2πi,​
"by hand".
Likes matt_crouch
To fill in a couple of important points regarding the comments above. Assuming that the contour is a closed curve. When applying the residue theorem, you do not need to know a lot about the contour. You do need to know how many times and in what direction it winds around each root, clockwise or counterclockwise.
Ok thanks for the replies everyone...
So the way I obtained the integral in the first place was to go from
$$\vartheta \rightarrow \lambda,$$ by using $$\lambda = e^{i\vartheta}$$
So i guess the contour is an integration over the unit circle like Zinq said.
Ok thanks for your comments
So further from this, my original problem was to calculate the so called Whittaker contour integral
so we start from
$$f=\int_{0}^{2\pi} \frac{1}{(x+izcos(\vartheta)+iysin(\vartheta))^{2}}d\vartheta$$
This should give $$f=2\pi/r^(3)$$
could someone show me how? Essentially i changed from $$\vartheta \rightarrow \lambda$$ where $$\lambda=e^{i\vartheta}$$ and then i tried the contour integral but I still don't see how one can get the function f above?
Relativistic Momentum, Mass, and Energy Momentum and mass (...), the classic equations for conserving momentum and energy are not adequate for the analysis of high-speed collisions. (...) The momentum of a particle moving with velocity ##v## is given by $$p=\cfrac{mv}{\sqrt{1-(v^2/c^2)}}\qquad{R-10}$$ ENERGY In relativistic mechanics, as in classic mechanics, the net force on a particle is equal to the time rate of change of the momentum of the particle. Considering one-dimensional...
