How can I use spherical coordinates to simplify the Fourier transform equation?
The discussion focuses on simplifying the Fourier transform equation using spherical coordinates. The equation presented is $$V(k)=\sigma_1^x\nabla_1^x\sigma_2^y\nabla_2^y\frac{1}{|\vec{r_2}-\vec{r_1}|}e^{-m|\vec{r_2}-\vec{r_1}|}e^{-ik(r_2-r_1)}$$, which involves terms related to Yukawa potential and requires integration techniques. The key takeaway is the necessity of applying spherical coordinates to express the distance between points, specifically using the formula $$|r_{1} - r_{2}|^2= |r_{1}|^2 +|r_{2}|^2-2r_{1}r_{2}cos\theta$$. The discussion also emphasizes the importance of understanding the gradient in spherical coordinates for further simplification.
  • Understanding of Fourier transform equations
  • Familiarity with spherical coordinates
  • Knowledge of gradient operations in vector calculus
  • Basic concepts of Yukawa potential
  • Study the application of spherical coordinates in Fourier transforms
  • Learn about the gradient in spherical coordinates
  • Explore integration techniques relevant to Fourier transforms
  • Research the Yukawa potential and its Fourier representation
Mathematicians, physicists, and engineers working with Fourier transforms, particularly those interested in potential theory and wave equations.
kelly0303
(This is part of a longer problem) Write the following potential in the momentum space:
$$V(r_1-r_2)=(\vec{\sigma_1}\cdot\vec{\nabla_1})(\vec{\sigma_2}\cdot\vec{\nabla_2})\frac{1}{|\vec{r_2}-\vec{r_1}|}e^{-m|\vec{r_2}-\vec{r_1}|}$$ where ##\sigma## is the Pauli matrix.
$$\phi(k)=\frac{1}{(\sqrt{2\pi})^3}\int{\psi(r)e^{-ik\cdot r}}d^3r$$
By applying the Fourier transform equation, and expanding the dot product, I get a sum of terms of the form: $$V(k)=\sigma_1^x\nabla_1^x\sigma_2^y\nabla_2^y\frac{1}{|\vec{r_2}-\vec{r_1}|}e^{-m|\vec{r_2}-\vec{r_1}|}e^{-ik(r_2-r_1)} = \sigma_1^x\sigma_2^y\nabla_1^x\nabla_2^y\frac{1}{|\vec{r_2}-\vec{r_1}|}e^{-m|\vec{r_2}-\vec{r_1}|} e^{-ik(r_2-r_1)} $$ But I don't really know what to do with this. Integration by parts doesn't seem to help too much.
There are a couple of things that I think you are needing for this problem:
1) https://math.stackexchange.com/ques...awa-potential-fourier-representation-integral
2) Follow these simple steps if you can:
## \psi(r)=\frac{1}{2 \pi} \int d^3k \, \hat{\psi}(k) e^{ik \cdot r} ##.
## \nabla \psi(r)=\frac{1}{2 \pi} \int d^3k \, ik \hat{\psi}(k) e^{ik \cdot r} ##.
This last equation is the result that ## ik \hat{\psi}(k) ## is necessarily the F.T. of ## \nabla \psi ##.
Some additional work might be in order to complete this problem, and I'm not even sure I would know how to finish it up, but perhaps what I gave you will help.
Try using spherical coordinates. In these coordinates ##|r_{1} - r_{2}|^2= |r_{1}|^2 +|r_{2}|^2-2r_{1}r_{2}cos\theta##. Also look up gradient in spherical coordinate.
