Complex Functions of a complex variable
This discussion focuses on visualizing complex functions of a complex variable, specifically Euler's formula and functions like z|-->z^2 and z|-->e^z. Participants emphasize the need to represent these functions in two complex planes: the z-plane for inputs and the w-plane for outputs. The challenge lies in understanding how to sketch these mappings, as they require a four-dimensional perspective due to the nature of complex numbers. Key insights include the importance of analyzing simple curves in the z-plane to derive their corresponding outputs in the w-plane.
  • Understanding of complex numbers, specifically the form z = x + iy.
  • Familiarity with Euler's formula and its applications in complex analysis.
  • Basic knowledge of differential calculus and function mapping.
  • Concept of complex planes and their dimensionality in visual representation.
  • Study the visualization techniques for complex functions using software like GeoGebra or MATLAB.
  • Learn about the implications of Euler's formula in complex analysis.
  • Explore the concept of mapping in complex analysis, focusing on the transformation of curves from the z-plane to the w-plane.
  • Investigate the properties of complex functions, including continuity and differentiability in the context of complex variables.
Students and educators in mathematics, particularly those studying complex analysis, differential calculus, and anyone seeking to improve their understanding of visualizing complex functions.
Solidmozza
Hi,
Im doing a course in Differential Calculus and we are up to Euler's formula and representing complex functions of a complex variable. I'm finding it really difficult to visualise/sketch these types of functions: z|-->z^2 such that {z=x+2i}, or z|-->e^z = w such that {z=(-1+i)t | t e R, t>_0}
Could someone please explain to me how to sketch these sorts of things, or direct me to an explanation? For instance, in the first of these above equations, I've gone z^2 = x^2 - 4 + 4xi but then I get mixed up with the axes: arn't they meant to be real and imaginary axis, not x and y, so what can I do with this x value?
Any help muchly appreciated!
Yes, of course you are going to have trouble! every complex number, z= x+ iy, requires two dimension so a graph of f(z) would have to be in 4 dimensions- 2 for z itself and 2 for the value of f.
Do you really need to draw graphs in order to do the problems you are given?
My fault - I didn't make myself clear. I realize fully that you would need 4 dimensions to draw it on one graph, however what I meant was that they want us to draw two complex planes - the z plane (inputs) and a w plane (outputs). For instance, if we chose a subset A of the complex numbers such that f:C-->C and A={z=x+iy|-pi<y_<pi} what are the set of output values of z maps to w, where w=e^z? Sorry if this doesn't make it clear either :S
Ah, I've never really liked that method! The best you can do is take some simple curves or lines in the z= x+ iy plane and sketch the result in the f(z)= u+ iv plane.
For example to graph f(z)= z2, look at the vertical lines z= x. Then f(z)= x2 which is just u= x2 (constant for each vertical line and so a horizontal line- but not evenly spaced and above the real axis for both x and -x). The horizontal lines, z= iy, give z2= -y2, again horizontal lines but below the real axis.
  • · Replies 17 ·
  • · Replies 27 ·
