Is the Proof for a Complex Inner Product Space Correct?
The discussion focuses on proving properties of complex inner product spaces as outlined in Schaum’s Outlines of Linear Algebra, 6th Edition (2017). The user demonstrated that for vectors u and v, the conditions a and d must be real positive, and b is the conjugate of c. The solution requires proving that a.d - b.c is also positive. The discussion emphasizes the importance of the inner product properties, particularly the conjugate symmetry and positive definiteness of the associated matrix A.
  • Understanding of inner product spaces and their properties
  • Familiarity with complex numbers and conjugates
  • Knowledge of matrix theory, specifically Hermitian matrices
  • Basic concepts of linear algebra, including scalar products
  • Study the properties of Hermitian matrices and their implications in inner product spaces
  • Learn about positive definite matrices and their characteristic polynomials
  • Explore the concept of scalar products in complex vector spaces
  • Investigate the role of eigenvalues in determining matrix properties
Mathematicians, students of linear algebra, and anyone interested in the theoretical foundations of complex inner product spaces and their applications.
hsazerty2
Summary:: Inner Product Spaces, Orthogonality.
Hi there,
This my first thread on this forum :)
I encountered the above problem in Schaum’s Outlines of Linear Algebra 6th Ed (2017, McGraw-Hill) Chapter 7 - Inner Product Spaces, Orthogonality.
Using some particular values for u and v, I proved that a and d must be real positive, and b is the conjugate of c. The solution indicates that a.d-b.c must also be positive, but i can't figure that out.
thanks for your help.
[Moderator's note: Moved from a technical forum and thus no template.]
Definition (Inner product) Let V be a vector space over IR.
An inner product ( , ) is a function V × V → IR with the following
properties
1. ∀ u ∈ V , (u, u) ≥ 0, and (u, u) = 0 ⇔ u = 0;
2. ∀ u, v ∈ V , holds (u, v) = (v, u);
3. ∀ u, v, w ∈ V , and ∀ a, b ∈ IR holds
(au + bv, w) = a(u, w) + b(v, w).
Your estimate meets above 1. How about 2. and 3. ?
EDIT
As pointed out in #3 for conjugate inner product
2. (u,v)=(v,u)*
properties
We're dealing with a complex inner product here.
Likes anuttarasammyak
first check the condition ##(u,v)=\overline{(v,u)}##
Theorem. A function ##f(u,v)=u^TA\overline v,\quad A=(\overline {A})^T,\quad u,v\in\mathbb{C}^n## is positive definite iff the characteristic polynomial of the matrix ##A## has the form
$$\sum_{k=0}^n a_k\lambda^k,\quad a_k\in\mathbb{R},\quad a_k\ne 0,\quad\mathrm{sgn}\, a_{k}=-\mathrm{sgn}\,a_{k+1}$$
Hi there,
Hello, @hsazerty2 !
:welcome:
@wrobel, Thanks for the reply, but i need to find a solution that does not involve the notion of characteristic polynomial or eigenvalues.
Is the below proof right ?
if f(u,v) is a scalar product, then f(u,u) must be positive for all u in C2, which means that the above matrix A must be positive definite, and for that its determinant should be positive. and i already proved that the above matrix is hermitian. So all the conditions are : a and d real positive, b is the conjugate of c, and the determinant is positive. Conversely, if all the above conditions are satisfied, then the matrix is hermitian and definite positive, so f(u,v) is a scalar product.
Right ?
  • · Replies 17 ·
