Complex log and Winding Number in Pi_1(S^1)
  • Level: Graduate
  • Thread starter Thread starter Bacle
    Complex Log Winding
1 reply · 2K views
Bacle
Hi, everyone:
I am confused about the def. of winding number of a loop on S^1
( on elements of Pi_1(S^1,1) ). The winding number is defined by
w(f):= [log(f)1)-log(f)0)]/i2Pi
One of the problems is that log cannot be defined continuously on
S^1, since complex logs can only be define in simply-connected regions that do not wind
around the origin --and S^1 fails both these conditions.
How does this definition then make sense.?
2) Also, in my old class notes, we use log to define a homotopy
between any two functions f,g with the same winding number:
f_t(x)=exp[tlog(f)x+ (1-t)g(x))
In which we seem to assume log is continuous. Just curious:
what would happen if g,f had different winding number.?.
I understand each homotopy class [n] in Pi1(S1) consists of
all paths that loop around n times. ft(x) above is clearly a homotopy between
g(x) and f(x)
I am hoping to understand better why the classes [n] and [m] are only homotopic
for m=n. I am aware that we construct the isomorphism by first using the fact that
the cardinality of Pi1(S1) is the same as that of the fiber
of any point under the standard cover by the reals, and that we show that the map
to the deck transformation group is an isomorphism, but understanding the log issue
will help me get more insights.
Thanks in Advance.
I'm surprised that your book said only that and nothing else.
One way to patch things up is to note that w(f) is by noting:
  • That formula is well-defined for paths in simply-connected regions
  • Such paths generate the fundamental groupoid
  • Writing a path as a sum of generators in two different ways yields the same value for the winding number
Another way is that the derivative of log(z) is well-defined on the entire circle, and you can define w(f) via integration.
Another way is to lift paths on the circle to paths on the Riemann surface for log(z).
