MHB Complex number as a root and inequality question
Darken1
Question 1:
(a) Show that the complex number i is a root of the equation
x^4 - 5x^3 + 7x^2 - 5x + 6 = 0
(b) Find the other roots of this equation
Work:
Well, I thought about factoring the equation into (x^2 + ...) (x^2+...) but I couldn't do it. Is there a method for that? Anyways the reason I wanted to do that was to use the quadratic formula afterwards where I guess one of the zeroes is x=i.Edit: Think I solved my own question 2 upon writing this
Question 2:
Let f(x) = (4-x^2)/(4-x^(1/2))
(a) State the largest possible domain for f.
(b )Solve the inequality f(x) greater than or equal to 1
Work:
Domain: [0,16) U (16,infinity)
x^(1/2) so x can't be negative (greater than or equal to 0) and it's a fraction so the denominator cannot equal to 0.
Multiplied denominator to the other side
4-x^2 >= 4-x^(1/2)
Eventually arrived to
x^2-x^(1/2) <=0 and 0<=x^2+x^(1/2)
Took the first equation and changed the first term
(x^(1/2))^4-x^(1/2)<=0
x<=1
Mathematics news on Phys.org
Darken said:
Question 1:
I think we can cheat a bit here and use the question itself to help us! If $$i$$ is a root of the equation, then there must be a factor of $$(x^2 + 1)$$. Does this make sense? In other words, we want to factor the expression, and thus determine the roots of the equation. One of which, will be i.
I get, $$(x^2 + 1)(x - 2)(x - 3) = 0$$ which has real roots at 2, and 3, and non-real roots at $$\pm i$$ (the advantage of this one is that we solve b) also).
Alternatively, and as you have said, we can simply let $$x = i$$, and see if whether we come across any strange results.
$$i^4 - 5i^3 + 7i^2 - 5i + 6 = 0$$
$$i^2i^2 - 5i^2i + 7i^2 -5i + 6 = 0$$
$$1 +5i - 7 - 5i + 6 = 0$$
$$0 = 0$$ and hence, $$i$$ is indeed a root of the equation.There are a few different methods for solving these, which ones have you learned for dealing with these polynomials?
I get, $$(x^2 + 1)(x - 2)(x - 3) = 0$$ which has real roots at 2, and 3, and non-real roots at $$\pm i$$.
For x^4+... I just try to convert it to (x^2+...)(x^2+...) format by guessing tbh. I know how to factor cubes, the quadratic formula, and how to divide one polynomial by another.
That's a good start, and yes, a bit of educated guesswork can come in handy at times.
I'll run through how i did it, and then perhaps someone else can provide a more formal or general method for solving. A few main things i used to help me solve were,
1. $$(x^2 + 1)$$ must be a factor (given in the question)
2. The product of all the factored constants must equal 6.
Because of 1., i assumed that there must be at least two other factors of the form $$(x+b)(x+a)$$. I did so, because we know there can't be any more x terms right? Otherwise we would have an $$x$$ to the power of a number greater than 4, which isn't in our original expression. So we have,
$$(x^2 + 1)(x+a)(x+b) = 0$$
At this point i got lazy and just 'trialed and errored' a bit, taking a and b as factors of 6 (2.). and knowing that the sum of $$a$$ and $$b$$ must equal $$-5$$. i.e., $$a + b = -5$$ and $$ab = 6$$, $$-2$$ and $$-3$$ are the obvious candidates here :p.
This approach is pretty adhoc, and i wouldn't recommend it (i'll probably get in trouble for it :p) while you're still learning. Sparkfun offers some not bad advice on factoring polynomials of degree 3 and 4.
I can't see the url outside of me replying. Anyways what about dividing the original equation by (x^2 + 1) and then attempting to factor whatever it is?
Not sure about that. Maybe i didn't embed them correctly.
Yes long division is a pretty common method. It's quite robust too.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
