MHB Complex number as a root and inequality question
The discussion revolves around solving a polynomial equation where the complex number i is confirmed as a root of the equation x^4 - 5x^3 + 7x^2 - 5x + 6 = 0. Participants suggest that since i is a root, (x^2 + 1) must be a factor, leading to the factorization (x^2 + 1)(x - 2)(x - 3) = 0, revealing real roots at 2 and 3. For the second question regarding the function f(x) = (4-x^2)/(4-x^(1/2)), the largest domain is determined to be [0,16) U (16, infinity), and the inequality f(x) ≥ 1 is solved, leading to the conclusion that x must be less than or equal to 1. The discussion highlights various methods for factoring polynomials and solving inequalities.
Darken1
Question 1:
(a) Show that the complex number i is a root of the equation
(b) Find the other roots of this equation
Work:
Well, I thought about factoring the equation into (x^2 + ...) (x^2+...) but I couldn't do it. Is there a method for that? Anyways the reason I wanted to do that was to use the quadratic formula afterwards where I guess one of the zeroes is x=i.Edit: Think I solved my own question 2 upon writing this
Question 2:
Let f(x) = (4-x^2)/(4-x^(1/2))
(a) State the largest possible domain for f.
(b )Solve the inequality f(x) greater than or equal to 1
Work:
Domain: [0,16) U (16,infinity)
x^(1/2) so x can't be negative (greater than or equal to 0) and it's a fraction so the denominator cannot equal to 0.
Multiplied denominator to the other side
4-x^2 >= 4-x^(1/2)
Eventually arrived to
x^2-x^(1/2) <=0 and 0<=x^2+x^(1/2)
Took the first equation and changed the first term
(x^(1/2))^4-x^(1/2)<=0
x<=1
Mathematics news on Phys.org
Darken said:
Question 1:
I think we can cheat a bit here and use the question itself to help us! If $$i$$ is a root of the equation, then there must be a factor of $$(x^2 + 1)$$. Does this make sense? In other words, we want to factor the expression, and thus determine the roots of the equation. One of which, will be i.
I get, $$(x^2 + 1)(x - 2)(x - 3) = 0$$ which has real roots at 2, and 3, and non-real roots at $$\pm i$$ (the advantage of this one is that we solve b) also).
Alternatively, and as you have said, we can simply let $$x = i$$, and see if whether we come across any strange results.
$$i^4 - 5i^3 + 7i^2 - 5i + 6 = 0$$
$$i^2i^2 - 5i^2i + 7i^2 -5i + 6 = 0$$
$$1 +5i - 7 - 5i + 6 = 0$$
$$0 = 0$$ and hence, $$i$$ is indeed a root of the equation.There are a few different methods for solving these, which ones have you learned for dealing with these polynomials?
I get, $$(x^2 + 1)(x - 2)(x - 3) = 0$$ which has real roots at 2, and 3, and non-real roots at $$\pm i$$.
For x^4+... I just try to convert it to (x^2+...)(x^2+...) format by guessing tbh. I know how to factor cubes, the quadratic formula, and how to divide one polynomial by another.
That's a good start, and yes, a bit of educated guesswork can come in handy at times.
I'll run through how i did it, and then perhaps someone else can provide a more formal or general method for solving. A few main things i used to help me solve were,
1. $$(x^2 + 1)$$ must be a factor (given in the question)
2. The product of all the factored constants must equal 6.
Because of 1., i assumed that there must be at least two other factors of the form $$(x+b)(x+a)$$. I did so, because we know there can't be any more x terms right? Otherwise we would have an $$x$$ to the power of a number greater than 4, which isn't in our original expression. So we have,
$$(x^2 + 1)(x+a)(x+b) = 0$$
At this point i got lazy and just 'trialed and errored' a bit, taking a and b as factors of 6 (2.). and knowing that the sum of $$a$$ and $$b$$ must equal $$-5$$. i.e., $$a + b = -5$$ and $$ab = 6$$, $$-2$$ and $$-3$$ are the obvious candidates here :p.
This approach is pretty adhoc, and i wouldn't recommend it (i'll probably get in trouble for it :p) while you're still learning. Sparkfun offers some not bad advice on factoring polynomials of degree 3 and 4.
I can't see the url outside of me replying. Anyways what about dividing the original equation by (x^2 + 1) and then attempting to factor whatever it is?
Not sure about that. Maybe i didn't embed them correctly.
Yes long division is a pretty common method. It's quite robust too.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
