Understanding Complex Numbers: Formulas and Applications
The discussion focuses on finding the values of m such that z^m = z for the complex number z = cos(7pi/6) + i*sin(7pi/6). The initial approach using De Moivre's theorem leads to the equation m*7pi/6 = 7pi/6 + k*2pi, but an incorrect value for k is identified. The correct formula derived is m = 1 + 12k, where k is an integer. Further clarification reveals that for m to be an integer, k must be a multiple of 7. The conversation emphasizes the importance of correctly applying formulas in complex number calculations.
Dousin12
1. Give a formula for the values on m such that z^m=z
z=cos(7pi/6)+i*sin(7pi/6)
2. If i use de movires i get
3. m*7pi/6=7pi/6 + k*2pi
But then i get the value that k=12/7, Which is the wrong formula.
The correct answer is 1+12k for k=0,1,2...
What happened to m in your answer?
Can you show us your work ?
m*7pi=7pi+k*12pi
m=1+12k/7
Okay, i got closer to the right answer now
Which is the equation wolfram alpha also get if i post my original equation. So it must be something wrong!
1+12k is the correct!
Dousin12 said:
m*7pi=7pi+k*12pi
m=1+12k/7
You have ##\ m=1+\frac{12}{7}k\,,\ ## & k must be some integer. I suppose from the context of the question that m must also be an integer.
m will only be an integer if k is an integer multiple of 7 , Right ?
let k = 7n .
11K
  • · Replies 19 ·
  • · Replies 18 ·
